Question about Motorola Mobility Rival A455 Cell Phone
When i slide the phone closed, it sometimes glitches badly
When i slide the phone closed, it sometimes glitches and shuts off. and sometimes half of the screen will be in the closed position, and the other half will be in the slid open position.
Why would automatic sliding door not pop out unless you pull handle?
Sometimes the lock on the handle from the interior gets stuck half way in/ out. Check its position. Mine does this periodically and then won't close, keeps opening. Also verify child safety close switch is in correct position.
May 01, 2014 | 2006 Toyota Sienna
My iPad screen won't rotate
Check in GENERAL settings to make sure that you don't have "use slide switch to lock rotation" checked. If not, when was the last time you shut the power on the iPad? Sometimes a power cycle fixes minor glitches like this. Good luck
Oct 23, 2013 | RIM BlackBerry Storm 9530 Smartphone
2000 Toyota Sienna power sliding door is jammed shut. Any solution?
Open the inside panel of the door by popping off the little white clips holding it on. The cable connected to the inside release button is either caught on something or has come lose. Check out this video - https://www.youtube.com/watch?v=MkC2OiOiE_U
Jun 10, 2017 | 2000 Toyota Sienna
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 25, 2010 | Nokia N95 Cellular Phone
I got nokia 8500.i chared it last night and since then the light wont go off ( side button lock srceen but it wont et ligt off).used half battery in a day. tried switch on and off, sim off, rechared,...
did you try taking the battery and SIM completely out of the phone waiting 15 seconds and then reboot your phone.
sometime in my experience this solved customers weird glitches.
if not please update your problem further.
Mar 26, 2010 | Nokia 5800 XpressMusic Smartphone
Glitching screen on samsung SGH a777
MY SAMSUNG SGH-A-777 SIM NOT UNLOCK.I TRY IT BUT NOT SUCCEFUL ME,PLEASE HELP ME.
Jan 31, 2010 | Samsung SGH-a777 Cell Phone
The automatic sliding door leaks, rattles, and doesn't always shut all the way. Have to give it a little exterior ''hip action'' to get the rear of the door to latch shut. Also sometimes it mysteriously...
i had an aerostar with the same proble, easy fix........there is a catch just inside the rear part of the car where the door closes, it needs adjusting, its about half way up, you can see it if you open the door fully, look just inside the door space , where the door fits into place....you will see 3 hex screws, there is also an adjustment catch on the door itself
Jul 22, 2009 | 2003 Ford Windstar
Stylus 300 won't stay on??
In the cameras I own, there is a setting where you can adjust the time the camera stays on. It's usually in the set-up screen. Is that setting miss-set?
Sep 12, 2005 | Olympus Camedia Stylus 300 Digital Camera
Motorola Mobility Rival A455  Cell Phone Logo
93 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
