Question about Sharp LC-32SB24U 32 in. LCD TV
Very low audio when adjusted to maximum - Sharp LC-32SB24U 32 in. LCD TV
  • 4,472 Answers
Does this happen on every source? Like on your cable and your dvd player? Have you checked all your sound menu options? Also how long have you owned the tv and how long have you had this problem for? Once I have more information I can assist you further.
Thank you,
Lee
Posted on Nov 19, 2009
What kind of tool do you use to adjust the carb? where can I buy one?
Hi Mr. Martin:
Not quite sure what kind of adjustments you want to do.
All the chain saws that I've experience with have two slotted screws, one high speed, and one low speed. There may also be an idle stop adjustment screw.
Adjustments typically consist of:
1) with the saw running, adjust the low speed screw so that the engine is running smoothly.
2) with the engine running, increase throttle to maximum rpm and then adjust high speed by leaning (screw in) until maximum rpm starts to drop off, then back out 1/3 turn.
3) let the saw return to idle rpm. should be smooth, and chain not turning. Adjust as necessary.
Tool required is small screw driver. It can help if you put a small piece of plastic hose over the blade so that it will not slip off the head of the screws.
Cheerfuls
Nov 16, 2015 | Garden
Ryobi 725r carb adjustments
Zama Carb? Turn both low and high meter screws 2 full turns counterclockwise, and idle speed control to maximum. Prime unit and start motor. Run for about ten seconds and then turn idle jet (clockwise) for maximum rpm and then lower idle rpms - readjust idle meter as necessary along with idle screw. Then gun unit at high speed and turn high screw for maximum rpm. Go from idle to max and make sure there is a smooth transition. If not play a tad with the idle mixture screw till that is achieved.
Oct 22, 2015 | Ryobi Garden
The audio output level is too low. How do i increase it? I have to turn the volume up on the TV almost maximum to hear a "normal" level of volume.
my experience says that the VCR/DVD recorder does NOT has a volume setting inside. Cables may be bad or connected to wrong input but most likely, the TV has a setting for the volume for any source and that is probably set to mid-range like on a PC sound control panel. Go the audio setup on the TV and see if you can adjust the level for each input.
Mar 03, 2014 | Memorex MVD4544 DVD Recorder/VCR
I am not getting enough volume of sound. I have an HP a384x. I have gone to the control panel and adjusted the volume for maximum but I still cannot hear things - the volume is too low. It especially is...
Try these fixes 1,reinstall sound drivers from cd, update drivers from web. 2,check you have connected audio pin(a green pin from external speacker) connected to green audio port behind the cabinet.
Jul 27, 2010 | HP Computers & Internet
My ma audio hk 898 will power on but will not push subs at all what can i do
Hello 76firebirdfo,
If there's no sound at all from the subs and you know they are good, there's probably no output from the amp. It's either wired incorrectly or it is defective.
If there's some sound but just not loud enough, then either the amp is not getting enough of an input signal from your head unit, or the amp settings are not adjusted properly. Adjust the crossover and gains for the best output to subs. LP filter on, crossover frequency at about 80-100Hz, and gain to maximum without distortion when head unit volume is at about 3/4 maximum.
Hope this helps.
Jul 14, 2009 | MA Audio Hard Kore HK-898 Car Audio...
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
Volume on surround sound speakers not working. Sound coming out of speakers but volume when turned to maximum is very low. Please help.
Most receivers you can adjust the different chanel levels. If you refer to the manual on adjusting chanel volumes in surround sound mode.
May 26, 2008 | Audio Players & Recorders
Left Surround Channel
Try to tighten the screws at the back where you insert your A/V jacks.
Thanks!
Apr 10, 2008 | Onkyo TX-DS575 Receiver
Sharp LC-32SB24U 32 in. LCD TV Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
