Question about Motorola Mobility L6 Cellular Phone
My screen light won't go out and I have tried adjusting my settings and shutting down with powering it off... What can i do?
Screen cannot be unlocked usink keypad and screen unresponsive after turning on screen with power button ,
they say if you tap the pad twice firmly in the upper left hand corner this will unlock the pad! some hp's has a light button on keypad, you tap the lighted button twice firmly just as you do with out lighted button
Apr 03, 2016 | HP Computers & Internet
When i turn off my computer the screen has a glow the screen does not go dark
Does it do it when you unplug and remove battery? When you turn off do you use the start menu shut down? Or push the on/off button? Adjust the Power Options in Control Panel. You didn't post your Acer Model number or your OS. In Windows 7, open Power Options, set to High Performance, set Sleep to Never, select Change Plan settings and Advanced Power settings to Sleep and Hibernate Never, scroll through Advanced Power settings to what to do when on/off button is pushed set to shut down, go through the settings one by one set to your preference.
May 26, 2013 | Acer Computers & Internet
Screen will not close if surveillance is on
Set the time in the Screen Saver to shut down. Or Open Control Panel,Power Options, Adjust Monitor shut down time.Advanced Power settings, adjust.
Jan 24, 2013 | CyberLink YouCam
Compac pasario c500 on/off light just blinks when I power on computer screen stays blank?
Shut down, unplug, remove battery, plug in, reboot. If it reboots, open Control Panel, Power Options, Advanced power settings, Change Sleep and Hibernate to Never. Adjust the settings to your preference. Set the Screen Saver time. When your laptop is not in use shut it down and unplug, this will prolong life and a reboot everyday will reset your laptop.
Jan 17, 2013 | Computers & Internet
Screen goes off
On battery the laptop will shut down and dim display to conserve battery, by tapping any key or touchpad it should come to life. That said, Open Control Panel, Power, Advanced Power settings, Change to High Performance, monitor shut down to never on AC , Select/Adjust advanced power settings to your preference.
Dec 29, 2012 | HP Compaq Presario CQ70-120US Laptop
The projector is stuck on the blue screen. It will let me change the input but it will still stay on the blue screen even though everything else is on and working.
Hello!
"blue screen" means: picture is all blue, but there is a signal coming through? Do you see channel logo? Menu? If so, blue CRT or CRT board is at fault. Depends on the age of the set. If set is fairly new, then try to bang on the neck of blue tube with rubber screwdriver hands. Very gentle! While set is working. If you see the retrace lines and TV shuts down then, CRT is at fault. If not, try to play with blue "screen" control of "focus block". Black plastic module with bunch of thick wires attachad to that. Has 3 "focus" and 3 "screen" controls. For each of the tubes. In many cases you'll be able to adjust "blue" down to normal. Usually, those controls are smeared with white paint and hard to turn by hand. Loosen those with little pliers, then adjust manually or via small "phillips" screwdriver. If nothing helps: CRT board is at fault and must be replaced or repaired. In this case you won't see any characters on blue CRT, just solid "blue".
good luck,
Alex.
Jan 20, 2012 | Sony Televison & Video
Replaced lamp, tv worked great for a week, yellow blinking status light, dust cover is secure and the switch is good. tv won't power up
Now the tv projection lamp tries to light up to the tv screen and shutting itself down,u hearing tv make alots of cliking noises to the tv set too?Yes,mean the Ballast board it is also dead,now must replaced the Ballast board too.The Ballast board only job are to ignite the tv projection lamp only.
Aug 09, 2011 | Mitsubishi WD62527 62 in. LCD HDTV
No red in the image on the screen
The adjsutment that you turned down was the G2 voltage to the red tube which is just a temporary fix for a CRT which has a short developing in it. Try turning up the red adjustment again only slightly to see if the red CRT ( tube) will light up
if it does and then the set shuts down its most likely the red CRT which is bad . If it lights up but you get retrace lines but doesnt shut down it possible that its the CR board ( Red CRT Drive Board) which is at the very bottom of the red tube.
May 26, 2009 | Sony KP-51WS500 51" Rear Projection...
Motorola Mobility L6 Cellular Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
