Furnace lights up then shuts off then 1-3 min kicks back on
Lights then shuts off sounds like relay in the board clicks when it shuts off
  • LBBP Feb 25, 2008
    Furnace clicks, goes on, pauses, click, click, goes on, pauses, click click.
    Kerosene furnace - tank outside (not that cold so not a frozen line or anything) - Just cleaned filter - Miller furnace - small -- originally for mobile home I believe. Age????? Serviced 9 months ago.
  • brian c
    brian c May 11, 2010
    Can you be more specific with make / model?
    Sergeant:
  • 288 Answers
The clicking noise is the heat fan relay. The limit control switch or the high temp thermal disc is what usually causes this. I am with the other guy as I need a little more info. The limit switch has a flat panel with 2 wires on it and held on by 2 screws. It goes inside the heat chamber and has a long probe on the back, usually 3 to 4 inches long. The thermal disc is just that, a disc about the size of a nickel, with 2 wires attached, and is usually not far from the limit control. If you can find these parts, by-pass them by removing the 2 wires on them and connecting them to each other. If this solves the problem, that's it. A faulty thermostat may do the same thing. Go to the thermostat and connect the red to the white wire, problem stops, change the thermostat.
Posted on Jan 12, 2008
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
I have a nordyne furnace model # e3eb-017h. Furnace doesn't kick on at all. No relay click or anything but it's getting power. Did the thermostat trick with touching wires together to kick on the furnace...
Check the pilot light sensor. Have seen this issue before. Sometimes after lighting need to hold it in longer. If it doesn't detect the lit pilot wise it will sit in safety shut down mode
Oct 28, 2014 | Heating & Cooling
RV Furnace Click
Hello.
First, try to clean the board, perhaps humidity make shortcircuits betwen logic gates. Second check capacitor, if someone is inflated, replace it.
Oct 26, 2014 | Heating & Cooling
Furnace kicks on and heats up for 5 min. then will shut down - no flame - main blower will run for a few min and then the whole cycle will start again. flame sensor checked ok with meter at approx 5.0
What is your temperature rise during the 5 minutes it does run? Could be overheating and kicking out on limit switch. Watch the diagnostic light for a code. (3 blinks means this, 4 blinks means that etc.)
Jan 09, 2014 | Amana Heating & Cooling
Heater turns on and heats garage to set temperature, than shuts off. when the temperature drops, the unit kicks on again. everything starts working again but only for a few seconds and than shuts off. it...
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution:You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor.If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 11, 2010 | Mr. Heater Natural Gas Garage Heater -...
Constant clicking sound coming from power box amana fridge
When you heard the click and the compresor stops ,check if it's very hot , if yes the compresor is of on overload and this could happend because 1 the condenser coil is dirty ,2 the relay is bad or 3 the compresor has a problem .Also check if behind the kick plate there's a timer (some units have it there or next to the cold control ) that could cause a problem too.
Aug 23, 2009 | Refrigerators
My lennox furnace kicks on, then it shuts off
It should have a diagnostic set of leds on the board, with the code list on the door and the control board itself. If it get to the pilot stage and the shuts down its most likely the gas valve. You can check for continuity from mv to c on valve, you should have it. Then with a valtage test from mv to a ground or common as you here the next click of a relay on the board after the pilot has had a few seconds.
Mar 12, 2009 | Washing Machines
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
My gas forced air furnace is shutting itself off after 2-3 cycles
there is a thermo-sensor switch next to the circuit board that tells the fan switch to turn on when the plenum is hot enough. this needs to be replaced.
Dec 01, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
1,966 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
