Question about Westinghouse WST1550 Wired Deluxe Upright Vacuum
How do I open the vacuum assembly?
I can't find a way to access the motor housing area. Can someone explain where the access points are or what screws will release the cover?
  • 6 Answers
You have to take the headlight lenses off with a small screwdriver. then a philips screwdriver to take the 2 screws out. one each side. then remove the foil shields on each headlight . then snap loose the rear plastic clips on the cover and it will come right off. it took me an hour to find out how and 10 minutes or less to take it off. watch for the micro switch on the circuit board being worn will stop the roller brush from turning.its a dollar part at any good electronics store ,but will have to be soldiered in or service might have a few from the westinghouse line .so will a broken belt which is a special grooved belt available from fantom at 18007987395..
Posted on Feb 27, 2008
  • ian walker Jan 19, 2013
    Great help.. Thanks Chad...I got the cover off and the belt is fine so I guess it's the electronics..have to find the micro switch you mentioned..Do you know if the whole circuit board might be available some where? Thanks again....
How to replace brush bar motor
It's not easy. The cleaner head assembly is hard to get off the main frame. When you get it there are 4 hex screws to the motor cover (hard to turn). Then a black and a white wire go into the unit. The wire cover can be removed with one hex screw but you still can't disconnect them. You have to remove the housing on the main drum (which I haven't done yet). I was looking for a picture like this all day. This is a shot I took today, apparently the only shot of the motor in the housing on the entire web. bc2d0b10-525a-469b-953c-57c5fd2f36e0.jpg
Jul 06, 2015 | Dyson DC17 Animal Bagless Upright Cyclonic...
How to remove fan from rsl3c ?
Remove the bottom plate screws & bottom plate. Remove the screws holding the motor and fan assembly to the nozzle housing. Remove the screws Holding the fan housing to the motor to gain access to the fan. Remove the bolt holding the fan on the motor shaft to remove the fan.
Sep 08, 2014 | Riccar Vacuums
Access motor on Bissell 3920 Pet Hair Eraser?
Hey Janalynn, you should contact one of BISSELL's Authorized Service Centers for assistance.
Here's a quick link to locating one of Authorized Service Centers, please click on the following link:
Feb 01, 2013 | Bissell 3920 Bagless Upright Vacuum
My vacuum sounds like it is screaming the entire time it is on. We have cleaned out every possible area, but it is still extremely load. Any suggestions?
Is it cleaning as good as it used to? 1) If not there may be an air leak.
A crack or a hole will allow air to rush in. The motor will make a louder noise when not under load. 2) Have you changed house locations, ie Country? Diffferent house voltage will cause this screaming.
Sep 12, 2012 | Bissell 87B4 Bagless Upright Cyclonic...
I have a clog in the vacuum line that comes out of the face that runs to the vacuum tube to the bag
To check for blockage in the fan housing, remove the bag assembly. Grip the lower bag housing and turn it counterclockwise for removal. If it has not been removed regularly to clean out debris, it may be hard to remove. Insert a screwdriver between the housing and the motor for leverage. For easier installation, wet the seal on the motor outlet before re-installing the bag assembly. Remember that the motor will not run unless the bag housing is fully attached.
Feb 13, 2011 | Kirby G6 Bagged Upright Vacuum
What charge for this service?
Actually there are no hidden screws on your Electrolux Epic model. This is the newer plastic body canister made by Aerus Electrolux. In order to open the vacuum cleaner to inspect the motor, first open the vacuum bag door and remove the vacuum bag. After the vacuum bag has been removed, keep the vacuum bag door open.
The two rubber furniture guards on both sides of the vacuum cleaner are actually what are holding the top housing and the bottom housing together. You'll need to slide both of these rubber furniture guards off in order to open the rest of the vacuum cleaner. They slide forward towards the vacuum bag housing which is why the door needs to be open.
In order to get these slides started, it's sometimes necessary to put a flat head screwdriver in between the back of the furniture guard and the start of the cord reel housing. Right after the rubber starts behind the word Electrolux. Fit a flat head screw driver in this gap, and it's sometimes easier to use a hammer, and hit the screw driver that's on the furniture guard facing the front of the vacuum.
With a little perseverance, you should be able to get the slide started, and when the slide starts to come out past the vacuum bag housing, simply grab the end of it with a pair of pliers, and pull the rest of it out of the vacuum.
Do this on both sides of the vacuum, and you'll be able to separate the two housings, and get access into the motor compartment.
If you have any problems, or would like me to take a few pictures of this being done, I'd be happy to do so. Please just rate my repair as helpful if you found this advice useful. I really do appreciate this.
Thank you,
Chris J.
Apr 07, 2010 | Electrolux Epic 6500 Vacuum
I need to remove the top of the motor unit on a Kirby Generation 3 to access the motor area of the vacuum
First remove the back, then remove the handle assembly. Then pop off the plastic switch cover and it has one screw on the back you will need to take out, then there are two screws in the front of the body housing and two on the back that you will need to take out and then you are ready to take the top cover off and get into the motor area.
Nov 28, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Also have a Kenmore Model 116. Power retractor not holding cord
The cord winder on these is spring loaded and has cog which is meant to lock with every full rotation of the spool the cord winds onto. It is tricky to work on.
Try pulling a bit more slowly and see if the rewind will stop.
The back housing on top of the vac needs to be removed to access the rewind. The housing snaps into place at the back corners, generally must be carefully pried and popped off by someone familiar with the vac. Some models may also have 2 screws under the lid in the bag area.
Sep 10, 2009 | Kenmore Canister Vacuum Vacuum
Dyson DC07 drive belt replacement
The other end of the drive belt the part you cant see goes to a clutch.
The clutch unit has 2 belts one is clutch to motor the second is clutch to brush roller.
You obviously look after your machine because you say you have had no problems with belts or clutch for 5 years.
Both belts & clutch can be worked on but its alot to explain so look at this site for service manuals.
Jun 01, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How to open the motor housing.
pls i want put music in my phone but its not possible i need ur help
Feb 11, 2008 | VAX Appliances 2000 Canister Vacuum
Westinghouse WST1550 Wired Deluxe Upright Vacuum Logo
168 people viewed this question
Top Westinghouse Vacuums Experts
Kevin Getz
Kevin Getz
Tom Chichester
Are you a Westinghouse Vacuum Expert? Answer questions, earn points and help others
