Question about Whirlpool SB160PEE Gas Single Oven
My Whirlpool (Model SBI30PER) the pilot light won't light seems like no gas is going to it...can it in anyway related to the timer?
  • bdreiver Nov 19, 2009
    It turned out to be in the timer...something in the start/stop timers seemed to stop the oven from working. After playing with the controls, there was a click and the oven was able to come on again.
  • Whirlpool Master
  • 43,501 Answers
The problem is probably that you have a bad ignitior. The type of ignitor that you have can go bad very easily and then you will get nothing, no glow, no gas or anything from your oven. Replace the ignitor and you will be hot and baking again!! You can find an ignitor for your oven here and other places. look around but this looks like a great price.
http://appliancehelp.com/Search_Model_Results.aspx?ModelID=850423&ModelNum=SB130PER5&mfgModelNum=&ManufactureID=3&Selected=D4N4HU0L&Position=3&mfg=Whirlpool&Type=&Mark=3
Posted on Nov 19, 2009
  • D. Floyd Kolb
    D. Floyd Kolb Nov 20, 2009
    Thanks for your feedback, that is something that I can include in my response to problems like this in the future. This is a common problem and any and all fixes that are possiblities I want to address.
    Once again, thank you for letting me know the exact cause of the problem and have a GREAT day!!
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
I just refilled my propane gas tanks and gas is coming through the top burners but there is no flame. I hear the clicking sound it makes when the pilot light ignites but no flame at all. What do I do ?
air won,t burn ther is air between the tank & the burner try using putting a flme at the burner then tun on the burner it should start after the air passes through the hose
Nov 23, 2013 | Whirlpool SB160PEE Gas Single Oven
We have a Magic Chef gas oven (model # CPL1100BDW) without electronic ignition. The oven isn't working. The oven pilot is out, can't get it to light, and the oven will not light - (obviously)....
Hello & Welcome to FixYa
If the pilot is clean and still won't light then the problem is with the safety valve that won't open and so needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Magic Chef Ovens
I have a frigidare gas stove I have changed the ingnitor bar and it still wont light, it seems if there is no gas coming in to the oven. Altough the top burners still work
Good day!!!
Your pilot light might have gone out. If this is the case then you have to re-light it. If the pilot light won't stay lit, then you might have to adjust the thermocouple or move the pilot light closer to the burner.
I hope this information will be helpful..
Thanks for using fixya..Have a nice day!!
Aug 27, 2011 | Explorer Appliances Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
Gas stove the oven pilot lights but not burner
I HAVE THE SAME PROBLEM WITH MY GE GAS RANGE. THE PILOT LIGHT IS ON BUT WILL NOT IGNITE THE BURNER. WHAT IS THE PROBLEM. LINDA jolin49@yahoo.com
Oct 01, 2008 | Whirlpool SB160PEE Gas Single Oven
Burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Nov 19, 2007 | Maytag CWG3100A Gas Single Oven
Whirlpool SB160PEE Gas Single Oven Logo
336 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
