Question about Kyocera FS-5025N Laser Printer
The print size for the paper is defaulting back to A4(97%) and I can't get it to stay on A4 (100%). Is there any way i can make this a new default.
    President:
  • 1,335 Answers
This sounds like you are setting the size in the application rather than the printer system properties.
To set the system printer properties, Click on Start>Control Panel>Printers
Select the Kyocera >Properties
Set the desired paper size, click OK.
The paper size should remain as selected until you decide to change it again.
You will still be able to temporarily change the printer properties for the application job.
Please rate this solution. Thanks.
Posted on Nov 19, 2009
Testimonial: "The answer completely 100% fixed my problem. I give it 100% rating. Thank you"
  • Bob Kitaji Nov 19, 2009
    I'm glad to help. Thanks for the rating.
How do I reset my SX215 to factory settings
When you are in the application that you are going to print from. Go to the menu bar, click on File - Page Setup. Here you should be able to change the paper size you wish to print out in. If you want to set the paper size by default to A4, then you will need to (Windows7) click on the Start button - Devices and Printers, select the printer that you want to change the paper size, right click on the printer - Printer Preferences, a dialog box appears, select the paper size you want in the paper size drop down list, click - Apply - OK. This should then have set the paper size to A4 by default.
Feb 26, 2015 | Office Equipment & Supplies
My Epsom 6500 keeps defaulting to 6 x 4 inch and best picture even though I try to get it to stay at A4, text.
Open printers in control panel, right click on the Epson and select printing preferences and chage paper size there, it should now keep the new size as it's default.
Jan 05, 2011 | Epson Computers & Internet
In tally HP laser jet 1020 is not accepting the paper size changes. though Paper type is changed from A4 to legal
just a point of interest have you tried this and have you set the size let it take, turn off for like 12 seconds and turn back on. to me its the same as with windows rebooting after any software change, they may not tell you but i always shut it off then back on to save any kind of setting or program, it may be a wasted step but i do it anyway.
the default paper settings
Make sure that the default paper size matches the width and length of the paper loaded in the tray. If the paper loaded in the tray is different from the paper size setting, the printer might print blank pages. For instance, the issue might occur if legal size paper (215 x 355 mm (8.5 x 14 in)) is in the tray, and the paper size setting is letter (215 x 279 mm (8.5 x 11 in)).
Follow these steps to check the default paper settings.
Click the Windows icon
Click Hardware and Sounds
Click Printers
Right-click the icon for the product, and then click Properties
Click Printing Preferences
Click the Features tab.
Compare the settings in the Size drop-down menu with the paper in the tray. If the paper in the tray is not the size in the Size drop-down menu, change the setting:
a. Click the Size drop-down list, and select more. The Size is window opens.
b. Select the size of the paper that is in the tray, and then click ok.
c. Click OK in the Printing Preferences window, and then click OK in the Properties window.
Jul 21, 2010 | HP LaserJet 1020 Printer
Printer has stopped printing full sheets, but when run test page it prints perfectly
Try this...Open your printer properties the same way you did when you printed a test page in Windows.
Look at the Effects tab. Look for the default print size and make sure it is set to 100%. Also check to make sure the paper size is set to 8-1/2x11 and not a smaller size paper.
Oct 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Whenever i change paper size from A4 to letter,
Don't set by using the "Print" option.
Go to [Start]
[Printers and Faxes]
right-click on the HP printer entry
! Don't select "Printing Preferences"! from there
Select [properties]
Select [Advanced] tab
Select [Printing Defaults]
[Advanced}
(I know, the screen looks the same, but it functions differently this way)
Change paper size to "Letter"
[OK, OK, OK]
*done*
Sep 25, 2009 | HP LaserJet 4350 Printer
Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Apr 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
Paper tray?
Two possible solutions;
1) Check the settings in the printer driver for the default tray. The other user could very well have changed them and set tray 1 as the default tray.
2) Check the paper size settings in the paper tray. Pull tray 2 out and check the paper guides. Make sure the paper guide in the front and left of the paper tray are set for the correct media type (letter, legal, etc.)
The printer reads the tabs in the back of the papertray to identify the paper size. If someone moved it while loading paper the printer identifies another paper size and defaults into the tray that has the size of paper required to print.
Hope this solves your problem.
Nov 19, 2008 | HP LaserJet 4100n Printer
A3 size does not feed automatically from tray on HP5550
Try this::: The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened. Let me know if it helps or I can research it some more.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 13, 2008 | HP DeskJet 5550 InkJet Printer
Default paper option
You can try to do these steps >>
click on start > control panel > printer n faxes > right click properties > print a test page > see if it prints in a correct format .
in case it doesnot >
delete the printer icon > from printer n faxes .
unplug the usb cable > go to device manager > uninstall imaging devices > restart the computer .
plug in the usb cable > u shud see found new hardware wizard > follow the steps n install teh basic drviers once again.
It shud be working .
Take care n thanks !!
Oct 31, 2008 | HP Officejet 5610 All-In-One InkJet...
Kyocera FS-5025N Laser Printer Logo
381 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
