Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Ice maker in our GE profile refrigerator is not working
Ice maker in our GE profile refrigerator is not making ice. The water dispenser works. The green light by the icemaker inside the freezer is blinking. Help please!
    Problem Solver:
  • 19 Answers
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
  • luv2mow Mar 24, 2011
    VERY GOOD INFORMATION AND IT STARTED WORKING. HOPEFULLY THAT DID IT!!!!!
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Control panel
Its faulty control panel, needs to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
GE Profile side by side with water/ice dispenser. The water is working but the water to make ice is not working, hence no ice. I had ice, used it all and then nothing.
I would try putting water in ice maker if it freezes ice maker is ok if so feplace water valve. careful only 4oz. of water in ice maker
Oct 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
May 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
1,778 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
