Question about Toshiba Satellite A205-S5809 Notebook
Laptop had a little drop..think the board is cracked.because the screen shows funny with all types of colors.but if i put some pressure on the left corner the screen shows perfect..talk to me..
  • mrpin65 Nov 19, 2009
    well actually i don't put pressure on the screen..when i press down on the left corner of the keyboard.it shows clear..probably didn't explain enough..thanks
  • 558 Answers
The screen is probably damaged usually if you put pressure on the screen and it changes the display.The screen is bad had the same problem changed it works fine now,no more twisting.
Posted on Nov 19, 2009
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
I dropped my dell notebook on the floor. The screen is 80% frozen however when I turn it off and reboot I can tell from the little corner I can see that the computer function but the screen stays stuck....
Try connecting an external monitor to your laptop via the 15 pin VGA connector located on the left side of the laptop.If the laptop display is normal on the external monitor then most likely your LCD (liquid crystal display) panel is damaged and needs to be replaced. The spider web effect is due to cracked display panel.
Sep 12, 2011 | Dell Inspiron 1525 Notebook
Broke the screen on my cob kyros can i get it fixed?
A broken screen isn't something which can be repaired with a software upgrade. There are two types of broken screens. An internally broken screen is where the image on the screen looks cracked, even though there is no physical signs of abuse. It will turn on but you'll see all these funny colors come onto the screen. An externally broken screen is basically if you took that laptop and dropped it onto something hard. You wouldn't get an image, you'd just hear some noise from the power supply.
Your best bet if you have a broken screen is to take it to a service technician to see what a screen replacement will cost. If the laptop still works you can also plug an external monitor into it. This won't let you use it so easily on the go, but at least you'll be able to use it at home.
Hope that helps.
Jan 02, 2011 | Coby Computers & Internet
Hi, my daughter has a dell inspiron 1545 laptop which is about 18 months old. today when she turned it on , apart from a 3/4 inch strip on the left hand side, the screen had a pattern resembling a large...
i think this is fixable, but just professional teachnician from service center can fix it, you just go to service center, and ask for fix that error
Dec 02, 2010 | Dell Inspiron 9100 Notebook
Dropped my blackberry pearl, now it will not turn on
inspect your screen, and try to look for tiny fractures / cracks.....you will need to use a flashlight, and look at an angle VERY CAREFULLY, because if it does have any cracks, they are gonna be hard to see (about the size of a cat hair, also look for "prism" colors.....as in rainbow colors.....if you see that, then the rails in the screen have cracked, and bled.). take the battery, sim card, and memory card out....wait 20 minutes, and put them all back in. try to turn the phone on....if nothing happens, take the phone back to the store, or find out about your warranty info if you still have one.....otherwise you're looking at getting a new phone.
i'm thinking your screen could possibly be cracked, but more than likely, something got knocked off of the circuit board, and will need to be repaired by the manufacturer either way.
Sep 20, 2009 | RIM BlackBerry Pearl 8100
Screen wires loose?
Sounds to me like its the cable going from the lcd to the motherboard. Probably needs to be reseated as long as its not broke from the fall.
Feb 14, 2009 | HP vs15 15"LCD Flat Panel Monitor
Screen showing funny lines and colors.
That would be the screen itself that needs replaced, if you needed the inverter board you screen would be dark and hardly visable
Nov 12, 2008 | Acer Aspire 3100-1405 Notebook
Convergence problem
The convergence ICs are located on the left board on a huge heatsink they should be STK392-110 or STK392-120. You can get replacement ICs at the following link and they also provide free step by step instructions on how to remove and install the new ICs.
http://servicemanuals.vstore.ca/
Mar 29, 2008 | Philips 60PP9202 60" Rear Projection...
Lexmark Z45 printer won't print
I am the same user as the guest above, I just found a solution. I took mine apart. I found that (when looking at the unit from the front with the cover off with the gears on the left) the 3rd gear from the bottom left had a crack in it. It was the gear that turns the 4 large round rubber cylinders from underneath the paper. Anyway, I kept turning on/off until the crack was on top and then I dropped a drop of Super Glue (red cap version for use on Rubber/Plastic/etc.). I put a little pressure on it using 2 thin screwdrivers in the gear teath to compress it but in looking back I don't think that was necessary. I think the crack in the gear was causing mine to slip so just making it solid again helped enough to make one work like normal again. I'll see how long this holds up. Good Luck. Scott.
Mar 01, 2008 | Lexmark Color Z45 InkJet
No red color on screen
sounds like you cracked the printed cuircut board on the crt drive board or in the video cuircut.. If you know how to solder look very carfully with thw set unpluged for crack on the crt pcb or the main board then scratch off the paint on the little pc traces on both sides of the crack and solder a wire across the trace
Apr 02, 2006 | Hitachi SSF420TR 20 in. TV/VCR/DVD Combo
Open Questions:
Toshiba Satellite A205-S5809 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
