Question about Panasonic PT-61HX41 61" Rear Projection Television
Convergence Problem - PT-61HX41
Hi, my tv suddenly went badly out of convergence. When I go through the convergence setup, I'm able to adjust the red and blue but the green is way off to the left and can't be moved back to the right. When adjusting the portion that shows the little crosses and I'm supposed to line them up, the bottom of the crosses on the right side of my screen are twisted. When watching the tv, the middle of the screen seems close to accurate. However, the edges are terribly out of convergence. Any help on what the problem is and how I can correct it would be greatly appreciated.
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
77ea520.jpg Convergence Problem - PT-61HX41 - f0900cb.jpgsrc="http://i.fixya.net/uploads/images/f0900cb.jpg" alt="f0900cb.jpg" class="h_mi" />
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replacedConvergence Problem - PT-61HX41 - 2c07611.png common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
TVConvergence Problem - PT-61HX41 - 2c07611.pngter fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from
www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 26, 2009
Convergence bad on Mitsubishi WS-65511
if you are not handy with soldering you might damage tv more if you tray to do it yourself,but you guys can send your board for repair to us for professional convergence repair with new Parts,3 month warranty.
just go to ebay site and look for TEXAS TV PARTS,or texasgreatdeals4you,then when inside store just type convergence board repair service,if you don't see repair service for your tv just ask via ebays mail,Thanks,
Jan 10, 2014 | Televison & Video
The yellow/green portion of the color spectrum is not aligned with the the other portion of the picture. Have checked the convergence adjustment and the crosshares for are wavy and off the screen. The net...
You have a "Static Convergeance" problem.
If the problem has been getting worse over the time period of say 3 months, then you have component failure. Probably electrolytic capacitors drying up.
If it went wrong all of a sudden, you possibly have dry joint, possibly contacts on plug/sockets.
Carefully check for problems and bear in mind that nothing will be very obvious.
Hope this helps.
Oct 31, 2010 | Panasonic PT-61HX41 61" Rear Projection...
Panasonic Cinemavision PT-56hx41e, wording on screen is red?
the convergence circuit governing the red picture has gone defective and needs attention possibly a convergence amplifier IC or and convergence coil at the red CRT went defective
Apr 28, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Red convergance is un-adjustable
Yes you can get the repair kit for your model at www.tvrepairworld.com the kits contain the two ICs and the 6 resistors plus the CD with step by step instructions.
Jan 06, 2010 | Panasonic PT-56WX53 53" Rear Projection...
Samsung:pcl4515r
You may still one more resistor opened , samsung most of the time its 2 low ohms but can be 3 it will be same value as other 2. I think they are 2.7ohms or 3.9 How to Enter Service Menu for convergence Turn TV off Press Mute 1-8-2-power now you should be in convergence use vol- and vol+ to select an item Use mute and menu to adjust when done Press ADD to save adjustments made.
Dec 12, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Sep 25, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Hello Again
Its possible one of the resistors were weak from the other ICs. Which way does the red refuse to move as that can help you pin point which resistor you should check
Jun 02, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX42
convergence IC bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Convergence off on PT 47
http://service.us.panasonic.com/OPERMANPDF/PT47WX49E.PDF Hi go to that link and you will get the manual for the TV and it will tell you how to adjust it.
Apr 02, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-61HX41 61" Rear Projection Television Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
