Send to friends
Send to: (e.g. Julie@email.com)
(Separate email addresses with commas)
Your name:
Your email address:
Message:
Car Security Systems Logo
Problem with the Ford Car Security Systems
Ford factory installed remote start I open door
By kzplumbing on Nov 19, 2009
ford factory installed remote start I open door and truck shuts off what can I do to program this so it works like it should
Best Solution (1 of 3)
posted 9 months ago
  • Rank: Guide
  • Rating: 97%, 22 Votes
Follow the following procedures for 2010 Ford vehicles with the door open shut down enabled:
1. Locate the override button and LED. On my escape the override button was at the bottom of the plastic by the driver's knees. The LED is attached to the harness behind this plastic, under the steering column. It is easier to find it once it's on.
2. Open the driver's door, press and hold the brake, turn the vehicle on.
3. While holding the brake, press and hold the override button, after 10-15 seconds the horn will honk 3 times. Let go of the button and the brake.
4. Push the override button until you hear the horn honk 5 times.
5. Push the brake until the horn honks 7 times, this is the "door open shut down" selection. The LED should be on.
6. Push the start button on the Key Fob. Do NOT hold it down, or it will reset everything.
7. The LED should now be off.
8. Shutdown the vehicle, and test it out.
Note: This procedure can be used to change the auto shut-off from 10 to 15 minutes as well. Instead of going to where the horn honks 7 times, go to where it honks 3 times, and turn the LED on.
Was this helpful?
Yes
No
18 people thought this was helpful
Add a comment
Solution 2
posted 9 months ago
  • Rank: Apprentice
  • Rating: 93%, 7 Votes
Thanks Roymoney! It worked like a charm! The override button was difficult to find on my 2010 Expedition Limited - it was taped to a wire harness under the dash between the power brake module and the emergency brake mechanism. I could not see an LED, but it doesn't matter. You need to push and release the override button (#4) several times to get the 5 honks - same with the brake - first time, one honk, second time, 2 honks, etc. Thanks again!
Was this helpful?
Yes
No
5 people thought this was helpful
Add a comment
Solution 3
posted 5 months ago
  • Rank: Apprentice
  • Rating: 0%, 0 Votes
I can get into the option banks but when I change option bank 2 - menu 7 - my 2010 f150 won't start via rmst. Instead of the engine turning over and starting, it honks 5 times (meaning key in the ignition error). Any suggestions?
Was this helpful?
Yes
No
Add a comment
Solve Your Ford Car Security Systems Problem Now!
Click here to get instant support from our best Experts
Please type the numbers below to complete your post:
Can't read it? Try a different one.
Type the numbers here:
Solve this problem
Bold
Italic
Underline
Insert List
Insert List
Video
Pictures
Insert Link
Links
Share your knowledge with the Fixya community today!
Popular Solutions for Ford Car Security Systems
I1996 ford fiesta with a radio fault /code ...
I have a 1996 ford fiesta with a radio fault. I removed the battery and now the radio is asking for a code. The Serial ...
HOW DO I DISARM A FORD TRANSIT ALARM TO PREVENT
HOW DO I DISARM A FORD TRANSIT ALARM TO PREVENT BATTERY DISCHARGING WHEN NOT USED EVERY DAY
alarm goes off on own
my arlarm in my 2002 ford exployer goes off on its own tried locking with remote doesnt help tried man locking doesnt ...
Central locking not working
My central locking key fob refused to work on my Ford Fiesta Ghia R reg. I visited my local Ford garage and they fixed ...
ford transit 1998 turbo diesel red light
No power, red engine light on dashboard temperature never hot Engine sounds OK turn off ignition, pull keys out, ...
Unsolved Problems rss
I've got a 1999 R6
I've got a 1999 R6 with the spy 5000m and I need to know the color code on the bike for the hijack pink and gray and ...
I have a dodge dakato
I have a dodge dakato 2004 there are 3 ignitions what wire from the control box is for the third one in the wiring ...
My remote will not do anything. i try to lock my
My remote will not do anything. i try to lock my car and it gives two quick beeps three times and im right by the car so ...
Radio only works when the ignition is off
my master lock 1590D isn't
my master lock 1590D isn't opening up. i recently changed the combonation but when i tried to open it it wouldnt open. ...
Solve this problem:
Bold
Italic
Underline
Video
Pictures
Insert Link
Links
What is this?
Get an Expert to Solve your Problem:
Top Car Security... Experts
Rank: Guru
Rating: 92%, 6945 solutions
Rank: Guru
Rating: 86%, 5365 solutions
Rank: Guru
Rating: 91%, 21643 solutions
Get an Expert to Solve your Car Security Systems Problem
Get Immediate Assistance!
Let our Experts solve your problem!
More than 2 million solutions and counting...
