Question about Dell Inspiron E1505 Notebook
Batteries not holding charge
I have an Insipron E1505 and have 3 different batteries for it. I just got a bigger power adapter for the laptop about 6 months ago when I had a problem of the laptop not recognizing the power cord. Now it seems all 3 of my batteries will not hold a charge. They charge up fine but when unplugged the batteries lose their charge quickly and then even with about 50% of the charge left in the battery the laptop will immediately go into hibernation. I would think it's the battery but how can none of them be holding a charge? I know there is a limited lifespan on the batteries but how can all of them go bad at the same time? Could it be something else wrong?
  • Claire Jan 11, 2008
    I bought the power pack directly from Dell. Who has the battery tester?
    Genius:
  • 1,067 Answers
They have a battery tester software online free 15 days or so that would tell u maby did u buy generic power pack also
Posted on Jan 11, 2008
Laptop will not power up
Take the battery out, plug in the charger and see if the laptop works. If it works, the battery may be the problem. Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop. Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity. If that light isn't on, try a different outlet. Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it. If it still does not light up, your adapter could need replacing. Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery. Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection. Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement. Unplug your laptop while it is running. If it still works, the battery has been charging. If it shuts off, or doesn't hold a charge very long, you have a bad battery. Unplug your laptop while it is off, then try to turn it on. If the battery is bad, your laptop probably won't turn on at all. Turn off your laptop's screen-saver when testing its battery. The screen-saver will conserve the battery and not give a clear time frame for how long your battery can really last. Click the battery icon on your laptop when it is unplugged. It can tell you how much battery life you have available. This icon is usually located in the bottom right corner of your screen and will provide the percentage of battery power you have left. Keep track of the time it takes to go from 100% charged to 1% charged. If this takes less than an hour, your battery is probably beginning to fail. You can also try this every week or two to see if your battery holds a charge for shorter periods. Factor in the amount of time you have used your laptop. Most laptop batteries last 2 to 3 years or about 500 charges. Wait a few days before determining whether a new laptop battery is faulty. New batteries sometimes take a few charges to build up to their maximum run time.
Feb 10, 2013 | Toshiba Satellite Computers & Internet
My multimeter reads .6 when testing a 1.5v dc battery. Why?
How old is the battery ? it might be past its use by date
Batteries can only be charged a certain amount of times before they need to be replaced
Frequent Charging Shortens Battery Life Frequent charging shortens the life span of a Lithium ion battery. Batteries should be charged only after they expend all their power. b> Switching Batteries Switching batteries helps preserve battery life: If a cell phone or computer user puts in a spare battery while separately charging the primary Lithium ion battery, that helps extend the life of both batteries. b> Removing Batteries Most laptops charge the battery when a user plugs in the AC adapter. Users can adjust this setting by changing the power options. Windows places this option in the Control Panel, while the Gnome Linux desktop places power options under "Administrative Tools". Cell phones incorporate their own power-saving features that the user usually cannot control. b> When to Replace a Lithium Ion Battery If a laptop battery does not hold a charge for more than a few minutes, a user must replace the Lithium ion battery if he wants to use the computer without an AC adapter. b> Other Ways to Extend Battery Life Storing a battery in a cool, dry environment causes a lithium-ion battery to last a little longer and reduces the frequency of needed battery replacements. Battery Bar - Free version available
http://osirisdevelopment.com/BatteryBar/index.html
Problems with power usage and battery life - Mr Fixit
http://support.microsoft.com/gp/windows_battery_power_settings b>
Feb 03, 2013 | Computers & Internet
My acer battery is not charging
Laptop battery problems are quite common among owners of all brands of notebooks. On average, laptop batteries last one to three years. Their exact lifespan depends on several factors, such as how much you use the batteries, the number of charge-discharge cycles and the quality of the batteries. Lithium-ion batteries begin to lose the ability to hold a charge over time. Before you replace a laptop battery, consider that there may be other reasons that the laptop is not working properly. You may be able to recharge the battery instead.
1.Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
2. Test the acer power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
3. Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
4. Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5. Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.I hope you find it very helpful. Best regards.
Jan 29, 2013 | Computers & Internet
Dustbuster batteries won't hold a charge.
The AC is not full sine wave. The diode is in the wall adapter
Jan 15, 2013 | Computers & Internet
My dell vostro 3300 laptop battery not charging since i re installed windows 7
2. Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Dec 09, 2012 | Dell Vostro 3300 Notebook
Laptop won't charge battery
Dec 05, 2012 | Lenovo Computers & Internet
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
Battery doesnt charge when plugged in
Aug 17, 2011 | Gateway MX7122 Notebook
My dell latitude c400 does not take a charge do i have to buy a new battery ?
Yes, most likely you may need to replace the battery. Try to get a different cell capacity this time (I do not know if you currently have a 6 cell or 9 cell battery). Once it's not keeping a charge it most likely has a problem.
Hope this helps...
Apr 18, 2010 | Dell Latitude C400 Notebook
My presario M2000 will not star orf come on. It has a new battery & power adapter.It gets very heated when charging. Helpme ???
Make sure you have an original adapter. Some of the REPLACEMENT adapters do not work very well with these computers.
ALSO make sure you have the right replacement battery. For instance in the {ressario 3000 series, there are two different batteries and one will work with some machines, but the higher level machine requires a bigger battery, although it is in an identical case.
Nov 28, 2009 | Compaq Presario M2000 Notebook
Dell Inspiron E1505 Notebook Logo
118 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
