Question about Zyxel Prestige 334 Router
I'm trying to reset my lynksys router but can't get past the initial login. Don't know my old user name and password. Admin default doesn't work. States access unathorized
  • 2 more comments
  • u2gard Nov 19, 2009
    thanks for your response.
    reset for 20 secs. and used lowere case but it still states "A username and password are bing requested byhttp://198.162.1.1 The site says:"level_15_access" "
    still not able to reset. maybe a hardware problem. thanks for your comments
    I finally got logged on using a diff computer. thx for all your help!
    President:
  • 1,015 Answers
You will need to use the reset button to reset it to the default settings. There is a small hole located on the router that you can use a pin to insert inside to push the reset button. Once pushed it should change it back to the default user name leave blank(no entry) and password is "admin"
Posted on Nov 19, 2009
  • muebe Nov 19, 2009
    What is the exact model number of your Linksys router?
    Glad we could help. It must be the administrator settings on the other computer that is keeping you from logging into the router.
  • 558 Answers
Lower case admin is the password.Reset the router ,use a paper clip or a pin reset button between the ports hold the button down for twenty seconds.
try 192.168.1.1 in the address bar in Internet Explorer.When the log on appears type admin in lower case and hit enter you should be in the you can set up the router again.Remember to save settings on each page and copy the network key and store it in a safe place for future use.
Good luck
Mp252 Audio Codes problem
maybe admin/1234 or you did not reset it, hold the reset button longer
Apr 16, 2014 | Computers & Internet
How do I get the password for my Wireless G Model WRT54G Router, if I can't remember it to configure a wireless printer that is asking for the password?
Which password do you need?
do you need the wifi key??
or the router password?
Try the default login information (make sure the computer is connected to the router):
http://192.168.1.1/
username: admin
password: [leave blank]
If this doesn't work, you will have to reset the router to it's default settings. There's a small reset button on the back. It is very small, it needs to be pressed with a pen.
This will reset to the default login information that I provided above.
PLease note that this method will reset any settings that have been already set in the router and you will have to set it again. These might include, port forwarding, wifi security and key, mac access list, etc.
Do not reset unless you know everything that needs to be set up again.
good luck.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
I secured my router network. I trying to get to set ups.... what user name and password I use? Admin for user name??
username: admin password: admin if that doesn't work, just reset it.
- reset instructions -
Push in the reset button on the back of the router, just to the left of the power port, for approximately 10-15 seconds, then wait 30 seconds, you will then be back at factory defaults. you then login to the router by typing http://192.168.0.1 into your browser, username: admin password: admin
Sep 20, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Cant login to my motorola sbg900 wireless router. i know my username and password and it will not work. I've tried resetting it by holding the button down in the back, but that won't work either. i...
By holding down the button in the back, you may have reset it to factory defaults for the password and username. Try using Admin for the user name and motorola for the password.
Jul 28, 2011 | Arris SURFboard SBG900 Wireless Router...
How to reset the password of the 3CR858-91 router? because I don't know the password.
the default user name is admin, try that with no password.
if that doesn't work to reset it you
1- Power OFF your router.
2- Disconnect all LAN cables
3- Loop the WAN port to a LAN port, in other words hook up a network cable from the WAN port to one
of the LAN ports
4- Power up, wait 15 seconds
when you have done that use the default username and password to access the router, but when you have done this make sure you set a new user name and password and keep it somewhere safe.
Robert
Jun 14, 2011 | 3Com 3CR858-91 Office Connect Cable/DSL...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
I forget user name and password
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
Jun 26, 2009 | D-Link DI 1135C-3/TP (DI-1135C-3/TP)...
Please help me to save SpeedStream 6300
Maybe try pressing the reset button on the back of the router. It'll reset everything but at least you'll be able to get into your router
Jul 12, 2008 | Siemens SpeedStream 6300 (33A6300001)...
Router stopped working
Try typing admin in the user and leave password blank see if that works, you can type the name of the router Like so Lynksys,belkin.ect. in the user name you can try to leave pass blank or type admin in that slot. I hope that helps somewhat. If not let me know I will find out how too. for u
Dec 23, 2007 | NetGear WGR614 Wireless Router
Zyxel Prestige 334 Router Logo
1,000 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
