Question about Motorola Mobility RAZR V3c Cellular Phone
I put my sim card back in my phone and now it want turn on
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Insert sim card
I'm not sure what the question is you are asking concerning a "sim card" but if it's How to put a SIM card in your cell phone you need a pin to put in the hole and it will pop open, However if your question is that your phone keeps telling you to insert a SIM card then you need to turn off your phone first and then go into the place where it's at and remove the SIM card and then put it back in and then turn your phone back on.
Aug 03, 2013 | Samsung E1107 Cell Phone
I swapped the sim card for another att card momentarily and then put my sim card back in the phone. The phones number is now that of the other sim card. How do i reset the card/get my old number back?
Have you tried doing a hard reset with your sim card in the phone. With the phone on, pull the battery out and put it back in, then turn the phone on it it doesn't start automatically. It should pick up your info from the card. Let me know if this helps.
Mar 28, 2010 | LG CE110 Cellular Phone
Where to put the sim card
Open the back cover of the phone, remove the battery,slip the sim card into the slot designed for the sim card. Later, install the battery,put back cover. Turn power on. That's it.
Dec 31, 2009 | LG HD4000
The v3 keep askin for my sim card but the card is in what can i do
Turn off the phone
Remove the SIM card
Wipe the metallic portion on the back of the SIM with a cloth
Put the SIM card back in
Turn the phone back ON.
If this did not resolve the problem, try using another SIM card so that you could verify if the problem is the SIM card or the SIM slot.
Have a great day!
Sep 18, 2009 | Motorola Mobility RAZR V3x Cellular Phone
I have a LG dare and forgot my password to unlock my phone
The first step is to find out if the password is on your sim card. If you already know that it is on your sim card skip this step. Turn off your phone and open it up. You should see your battery. On most phones your sim card is located under the battery. When you find your sim card remember exactly how it goes into it's slot and take it out. Put the battery back into the phone and turn it back on. It will tell you that your sim card is missing and on most phones ask you if you want to start without a sim card. Press yes and see if it asks you for your password. If it does not, then the password is on yor sim card. Put the sim card back into your phone and call your service provider. Tell them that you forget the password to turn on your phone. They should be able to tell you what yor password is after they ask you a few questions. If the password was not on your sim card, then call your cell phone provider and ask them how to reset your password. Service provider: Verizon is a service provider. cell phone provider: LG is a cell phone provider.
Aug 17, 2009 | Samsung SGH-e315
Cant get my sciphone to work
okay turn your phone off take the back off ,battery and take the sim card out now put the battery back in with out sim card .. turn on. now go open sim and close sim 2... turn off...remove back and battery put sim card in slot 1 make sure its in all the way put battery and back on ... turn the phone on... give it a few minutes it should work....
Jun 06, 2009 | Dual Electronics CECT P168 Cellular Phone
Phone doesn't recognize SIM card Samsung T429
turn off your phone, take your simm card out and put it back in right and all the way in turn it back on should work
also check your settings for your local carrier
May 14, 2017 | Motorola Mobility V66 Cellular Phone
HELP....phone reads "enter sim card" when sim card is in the phone
YOU HAVE TO CLEAN THE GOOLD COATED TERMINALS WITH A SPIRIT WERE THE SIM ENTERS AND ALSO CLEAN THE SIM WITH DISTILLED WATER OR SPIRIT DUB DONT RUB.DONE BY DOGY
Aug 02, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
