Question about Eureka 2961AVZ Bagless Upright Vacuum
Brushes do not spin when it is on low carpet you have to have the knob on high carpet for it to work.
  • 701 Answers
That means that the belt is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet. The lower the setting the more resistance. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Posted on Nov 19, 2009
2 Suggested Answers
SOURCE: no spin
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=782631
No spin
Posted by erin_david on Jul 14, 2008
Vacuum's brush does not spin on (low) carpet unless switched to "high" but then roller does not pick up hair on carpet. Belts are in good condition. Maybe belts are loose?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Your problem is that you may need to change the belt every 4 to 6 months as a recommended belt change on the vacuum and also keep an eye on the brushes or brush strips; they also help in the vacuum working properly. Here is a typical belt change on a Hoover. Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 15, 2008
Why is it such hard work to hoover the carpet with the dyson dc 33.it is really hard just pushing it across a new carpet.
Are your belts working and is your power head set too low? Try raising it up one or two clicks. A broken belt will not let your brushes spin and a spinning brush will help it go on carpets.
Aug 20, 2016 | Dyson Vacuums
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
My hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Rotary brush does not spin when using on carpet
The brushes are usually belt-driven. You may need to replace the belt.
Dec 16, 2017 | Dyson DC29 Animal Vacuum
Brush bar not spinning when set to high or low on carpet
1) adjust the belt, see for broken or worn, and replace
2)see for brushroller obstruction, and clean it and repair
3) see if the brushroller without belt run smooth, otherwise repair and fix it.Lubricate.
4)See if the motor run without load( NOT belt+brushroller) very well. in negative case repair motor.
God bless you
Jul 15, 2012 | Vacuums
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Brush Bar doesn't spin belt is ok.
There is a round knob on the side of the vacuum that says carpet, floor, move knob into carpet position
Aug 26, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My brushes wont turn once the vacum is on the carpet.
If they are turning when they're off the carpet, then you have the brush height setting set too low. There should be a dial somewhere near the brushes, some say things like "high" to "low" or "high pile" to "low pile." Turn it one notch towards high/up and try it again, and keep turning one notch and trying until the brushes turn. You want them as close to the carpet as you can get them without them stopping. If this doesn't fix it, you have to be more specific as to whats going on.
Aug 19, 2009 | Dirt Devil Vacuums
I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Mar 08, 2009 | Eureka 402A Bagless Upright Vacuum
No spin
No spin
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Eureka 2961AVZ Bagless Upright Vacuum Logo
155 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
