IBM T860 Monitor (9494HB0)
I just bought one IBM 9494 HBO monitor. It came with no manual, cables etc, nothing but the monitor itself, What kind of cable do I need? I was told by the seller I can use my old monitor cables to power it and view it. Is this true? I don't want to even try until I get a confirmation from one expert like you.
Some specs that I don't understand very well. Thank you kindly.
Model Number IBM T860 Monitor (9494HB0) Monitor Type 18.1" Flat Panel LCD Max resolution 1280 x 1024 Dot Pitch 0.28mm Dimensions Width 15.6" Ports DVI and VGA Ports Video Cord Included (VGA) Power Cord Included (doesn't need ac adapter) Condition Used. Very Good condition. Works Fine. Warranty Other Notes n/a
    Brigadier General:
  • 6,966 Answers
Assuming that nothing is electronically wrong with the IBM 9494, it should work with the old monitor cable (VGA) as well as the old monitor power cord.
Kind regards.
Posted on Jan 11, 2008
  • Louie  Role
    Louie Role Jan 11, 2008
    Hi again,
    18.1" - viewable screen size;
    1280 x 1024 - maximum screen resolution that you can set in your display properties of your PC;
    0.28mm - dot pitch specs for sharpness. the lower the better/sharper;
    DVI and VGA Ports - can accept either. VGA - Analog 15 Pin Mini D Sub connector; DVI - newer digital visual interface connector;
    doesn't need ac adapter - some other versions uses an adaptor similar to laptypes charger. this version is straight plug to an outlet;
    Condition Used - chances are refurbished unit. this model has been discontinued sometime back
    Very Good condition. Works Fine. - should work OK but you need to check it for scratches, dead pixels, backlight evenness etc.
    Warranty Other Notes n/a - not applicable.
How can i fix the continous on & off blinking of my ibm l170p monitor
If your monitor is blinking or flickering increase the refresh rate.
Apr 07, 2012 | IBM ThinkVision L170p 17" LCD Monitor
Monitor screen not center
Dear David,
It seems that your operating system is correct and a problem there is with the monitor itself.
May i please know what kind of monitor r u using (is it Digital or Analog type)
1 Digital type monitor.
In this kind of monitor there is no problem with the operating system. you can manually set the monitor by the button given on the monitor itself. try playing with them and your problem will be sorted if not then call the technician.
2 Analouge type monitors.
In this monitor some old monitors have some rotating (volume control type of switches) in the back of the monitor where the power cables are connected. try playing with them it will help. otherwise you have to call for ur computer vendor.
bye and thank you
Gagan
Mar 13, 2011 | Computers & Internet
We bought a used IBM NetVista and have a monitor problem
The video card is the most possible causing error like this. The cables are either connected or not.
Feb 24, 2010 | IBM NetVista PC Desktop
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't install ibm monitor 9494 hbo
Go to manufacturer website, go to support, search for your model number then download any updates or drivers listed and install...cheers
Apr 11, 2009 | IBM 9494hbo 18.1" Flat Panel LCD Monitor
Lamp cicuits in lcd monitor
AnBparts ebay store is very helpful.
They have this IC in small qty.
I've made several purchases from them and they are very reliable.
Here's a link:
http://cgi.ebay.com/AO4600-4600-POWER-MOSFET-INVERTER-PARTS_W0QQitemZ370160819357QQihZ024
Thanks,
Chris
Boise LCD - monitor repair
www.BoiseLcd.com
sales@boiselcd.om
Mar 16, 2009 | Computers & Internet
Ibm 14"crt monitor white light is blinking screen is blank
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Oct 07, 2008 | IBM E54 15" CRT Monitor
Schematic for T860 monitor
yes,, what you need is all ready in store
Aug 31, 2008 | IBM T860 Monitor
Computers & Internet Logo
296 people viewed this question
David Payne
David Payne
