Question about Mitsubishi Televison & Video
The picture on my TV Mitsubishi Model CK-35402 keeps rolling.
The picture on my Mitsubishi TV Model CK-35402 keeps rolling. There is no Vertical Hold Button on the set. What do I need to do? Thanks for your advice.
  • 236 Answers
SOURCE: Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Posted on Mar 10, 2007
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi VS-4506R No vertical hold
Rolling picture
had a few with bad capacitors
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Posted on Feb 07, 2008
  • 1694 Answers
SOURCE: vertical hold adjustment
Loss of vertical sync or any other problem with your Mits is
likely caused by bad power supply capacitors....they are made by Rubicon and are notorious "leakers"......very tedious and
expensive to fix...................good set back in the day.......T.
Posted on Mar 10, 2008
  • 375 Answers
SOURCE: picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Posted on Mar 27, 2008
  • 236 Answers
SOURCE: vertical hold on tv
no control over the remote..but impossible not to have vertical hold control in the TV itself. it should have one maybe at the back.
Posted on Apr 07, 2008
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
Dont remenber parental code for my 1994 mitsubishi tv model#ck-35402 and serial #513741
When the TV asks for a code use the Mitsubishi remote and press 9 and QV simultaneously. This will allow you access again. Once in reset to another password.
Aug 28, 2010 | Televison & Video
I cannot find vertical hold
The sync is automatic. There are no knobs to turn. If the picture is rolling, look first to the source connection and make sure your tv has a solid vertical sync connection. If you are using the RF input then the issue could be within your small signal board also known as the SSB. Good luck.
Mar 23, 2009 | Televison & Video
Mitsubishi CK-3526R TV
not sure what light picture has to do with problem  but no there is no  vertical hold control  prob bad electrolytics invertical feed back circuit, need tech..
Dec 07, 2008 | Mitsubishi WS-55807 TV
Vertical hold on tv
Apr 07, 2008 | Audiovox AVT-1475 13" TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Vertical rolling
Mar 04, 2007 | Mitsubishi WS-55807 TV
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Televison & Video Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
