Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printer will read memory card, but i cannot access from pc
I swore I once read my sd card from my pc, but now the printer will read memory card, but i cannot access the sd card from my computer anymore.
  • Canon Master
  • 32,281 Answers
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on Nov 19, 2009
How do I use the Micro SD port?
hi.
sd port is use for read yr sd card.. put yr sd card in sd port then yr can read it from clisk my computer icon and ten yr card will be locaten in g/h/f or try click 1 by 1 memory stick drive
regards
Feb 21, 2011 | eMachines Desktop / AMD Athlon Processor /...
Have an HP L7680 all-in-one Just received a Panasonic Limuix camera and cannot read the SDHC memory cards in the SD slot - Printer posts an error
No, it's not possible, it'll never read SDHC in the SD slot. SD slot will only read SD, Mini SD (with adaptor) and Micro SD (with Adaptor). If there's no SDHC card slot, then it doesn't support SDHC Card. The lists of supported memory card are listed below:
CompactFlash™ Type I and II,
Secure Digital/MultiMediaCard/Secure MultiMediaCard (SD),
xD-Picture Card,
Sony Memory Stick®,
MagicGate Memory Stick,
Memory Stick Duo,
Memory Stick Pro
I hope this clears your doubt.
Note: SDHC and SD are different Memory Card types.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | HP Officejet Pro L7680 All-In-One Printer
I get a card reader error on my printer when i insert my PNY Micro SD card
Has the card worked before.If it is the first time you have tried,is the SD card an SDHC,as some printers will not read these.Try a standard SD card and see if your printer reads that.Hope this helps.
Apr 12, 2010 | PNY 2GB microSD Memory Card
Memory card problem
Hi there
It some times becaous of the printer driver, you can try unstall the driver and then reinstall the driver back but make sure that your USB lead is out and no memory SD card in it when you reinstaling the driver also make sure the lock is not on the SD card when you try again, and also some times it got a menu on the LED screen that lockes the card from the PC reading it.
All the Best : Pineworks from Wales UK
Feb 17, 2010 | HP PSC 2410 All-In-One InkJet Printer
Memory card error message when sd card inserted
Try to read the card in another card reader or a computer that has a reader slot. If it can read it then you may need to download a driver for that card to enable your HP to read it. If on the other hand your computer can read identical cards made by the same SD manufacturer as your unreadable SD card then there may be a problem with the connection of your pc to the pins in this particular SD card. In that case, you need to transfer the files from the card to another device and load them to your pc.
Jan 09, 2010 | HP Photosmart 3210 All-In-One InkJet...
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
Memory card unformatted
If there are sd card error, you cannot format your sd card. you may get messages like
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
Nov 05, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
My printer (Canon MP830) will not read my memory card from my camera. an SD card. You can print straight from the card. I press "Memory Card" as the source on the top of the printer and select "Print while...
Did you let the camera format the sd card before you took your pictures? Have you tried another sd card? Its possible the pc did not close the card properly so the printer does not see it. I would try another card before going any further. Make sure your setting on the printer is set to read only (in "Other" settings) if at read/write you will not be able to print.
Aug 17, 2017 | Canon PIXMA MP830 All-In-One InkJet...
Sd card in adapter from cell phone will not work
The card is not supported if the printer is not reading it.
Jan 12, 2009 | Lexmark P4350 All-In-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
383 people viewed this question
old marine
old marine
