Question about AT&T Blackberry Curve 8300 Smartphone
Track ball requires multiple press to get it to do anything
    Scholar:
  • 87 Answers
Hi, to change the trackball or trackpad sensitivity of the BlackBerry smartphone, complete the following steps:
1) On the Home screen, go to Options > Screen/Keyboard.
2) In the Trackball or Trackpad section, click Horizontal Sensitivity or Vertical Sensitivity to change the sensitivity level.
3) Press the Menu key and select Save. The new sensitivity levels are saved.
A higher sensitivity number indicates a higher sensitivity level for the trackball or trackpad.
The trackball user interface found on certain BlackBerry smartphones is similar to the trackball used in a mouse in conjunction with a desktop computer.
In the event debris comes in contact with the trackball and affects the usability of the BlackBerry smartphone, rapidly roll the trackball up, down, left, or right to potentially correct the problem.
If rapidly rolling the trackball does not correct the problem, please contact your wireless service provider for support options.
Try to re-install the BlackBerry Device Software using the application loader tool, before you re-install the software please back up the BlackBerry smartphone data.I hope this information will be helpful to you
Posted on Nov 20, 2009
My blackberry pearl wont delete multiple messages at one time
There's an up button. Keep it pressed and scroll with the clitter/track ball.
Feb 06, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Tip
Shortcut for exporting multiple tracks
While not mentioned in the manual (page 68 dealing with usb export) you can indeed select multiple tracks to export to the fat partition at once. Under the 'wav in/out' menu item on the 'usb export' you'll see a track list. Simply press the 'insert' button next to any tracks you want to export and a check mark will be placed next to the track which flags it for export. When you press enter it will export all the checked tracks as wav files to the fat partition.
on Jan 04, 2008 | Tascam 2488 Portastudio Multitrack...
2002 Silverado Ball joint Replacement
You are correct sir. Even without splines, they require some type of press. You may be able to rent a ball joint press from one of the parts houses. I know advance auto and Autozone both have loaner tools.
Jun 11, 2009 | 1999 Chevrolet Silverado 1500
Ghb middle marble
Check the settings in the bios to enable the track ball. Most of the time that is where it is enabled or disabled. You can also check Dell's support website for additional software that may allow you to configure additional settings (similar to IBM/Lenovo Thinkpads).
I don't recall the specific key to press to get into the bios, its either F1, F2, F10. You need to do this from a cold start when the laptop is off. Press the power button and when you see the Dell logo, look for the bios settings key to press or press one of them that I suggested. Sometimes this may go by quick so you need to be quick about it as well.
Hope this helps!
Oct 17, 2008 | Dell Latitude C600 Notebook
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl
First, turn off the device. While pressing down firmly on the track ball roll the ball in all directions.
If that doesn't work, then you may need to take out the track ball and blow it out with compressed air. The link below shows how to disassemble the track ball:
Oct 01, 2008 | RIM BlackBerry 8700c Cellular Phone
Track Ball
Your track ball may simply be dirty. Get a q-tip wet with rubbing alcohol and rub your track ball and repeat until the q-tip stays clean. Hope this helps!
Jul 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Keyboard and tracking ball problems
Sounds like you have 2 different problems. Your trackball probably needs to be replaced and also your keypad needs to be cleaned or replaced.
May 19, 2008 | AT&T Blackberry Curve 8300 Smartphone
MY sk3 track ball is no longer working.
I Can Sell you The Trackball Peice For $35 and if you live in nyc i can even install it for you for another $5, Just Drop a Line to Me 347.845.7151
Nov 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
AT&T Blackberry Curve 8300 Smartphone Logo
409 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
