Question about RCA 27F650T 27" TV
Static My TV was on and I wiped it with a towel. Now all my tv does is tur. on and off can you help?
Front pannel
Posted on Sep 24, 2008
6ya staff
SOURCE:
What to use on the t.v. screen to clean it?
Turn off power , touch screen to release static electricity , use plain old Windex and paper towels...
Nov 13, 2017 | Televison & Video
How to Clean a Flat Screen TV?
Use a screen cleaning solution, very cheap little canister of anti static spray and usually comes with lint free cloth for light polishing.
Couple of quick squirts of solution then very gently wipe over the whole screen until all the dust has been absorbed and the wet streaks evaporate.
Don't need to go mad scrubbing, just light polishing.
A damp cloth is just as good but only damp and not dripping water, just wipe over screen. The only problem with that is it leaves streaks so just wipe over with a dry kitchen towel or something similar.
Oct 19, 2016 | Televison & Video
How do I clean a Samsung tv flatscreen that has had coffee spilled on it? It has been about a week.
Try equal amount of water and vinegar. Spray on clean dry lint free cloth then wipe the TV in the same direction, upand down or side by side...Don't over saturate the cloth...
Feb 11, 2015 | Samsung Televison & Video
New laptop touch screen erratic after cleaning
Sounds like static to me. was the laptop off when you cleaned the screen? Remove battery for a little bit use a paper towel or tissue to wipe screen down. Replace battery turn back on and calibrate screen. I hate using screen wipes. I just use small amount of water on "imitation chamois" cloth. They don't seem to create static. Hope this helps.
Mar 03, 2014 | Computers & Internet
Could wiping our 42" Vizio TV with a towel make our color change on the TV?
if you used any cleaner with chemicals in it that would leave streaks that cannot be removed, clue to this would be with set off you should be able if that happened to see it on the screen with the set off.
Otherwise there are a lot of things that can and do go wrong--a suggestion= you can post a video question here, take a video and upload it along with the brand and model number of the set in the text part of the question and post it in Flat Panel TV sets--if you want you can in the title also mark it Attention SD tech which is my user name here--if I see it (I do not miss too many) with the video I will at least be able to see what you have and make a suggestion on this problem.
this video feature is new here on Fixya so be patient.
SD TECH
Dec 19, 2012 | Vizio 42 in. LCD TV
My plasma tv won't tur on is there any way to fix
Not knowing model number here are some general things:
Apr 04, 2012 | Sharp Televison & Video
How do i clean the tv screen? and do you know were to get a replacement protective screen?
Its a simple Job 1. Buy anti-static wipes from nearby grocery.( 3M Scotch Brite High Performance Cloth is an excellent choice for screen cleaning 2. Turn off TV and disconnect it. 3. Now wipe off the dust without much pressure on screen. 4.Use a water dampened, non-abrasive or cotton cloth to wipe across the TV screen's surface to remove pet hair, dust and fingerprints. Dry the surface of the TV screen immediately after damp wiping the screen. also you can Buy the screen from different sources as per your convinience. which should not cost You more than $ 10.00 i guess
Cheers!! Gizokieth
Sep 10, 2009 | Televison & Video
Toshiba Television will no turn on, timer record lite flashes when trying to tur on T.V
Sep 05, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Dirty tv screen on plasma
Hi there
You get special cleaner for these screens from any good AV or PC shop.
Apr 11, 2008 | Office Equipment & Supplies
Screen blank
use the towell trick! Wrap the 360 in 2 towells turn on and leave running for 15 minutes. It gets very hot but after the 15 minutes turn off the console and power it back on again and it should work. Dont know if this is a permanent fix but my 360 hasnt broken again so far. Dont ask me how but it works, google it if you like. It also cures the 3 red lights problem.
Jun 22, 2007 | Microsoft Xbox 360 Console
RCA 27F650T 27" TV Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
