Question about Astoria Argenta SAE-2 "Big Gulp"
Overflowing from valve on top of boiler on astoria sae junior also one button on control panel working intermitantly
  • Astoria Master
  • 1,711 Answers
On the top of the boiler is also the boiler water lever which might be dirty or full of scale. you nee to remove it clean it with a brush. the button migh iit becoming wet from water from above problem so ceaning the lever you can solve both. The button might already damge if you have work the machine for along time with button wet.
Posted on Feb 17, 2010
Why is water leaking from pressure release valve?
there can be two reasons I can think of that water drips from that valve :
1: thermostat for boiler is defective and not keeping boiler at proper temperature
2: minerals in water deposited inside valve and keep it from sealing off well
Dec 01, 2015 | Astoria Argenta SAE-2 Espresso Machine
Astoria Divina SAE/2N 2 heads. What would make the spout in between the heads be only cold water and the water level gauge shows all the way at the top of the glass?
If by spout you mean tea valve, it could be that the economizer mixing solenoid valve is set to deliver more cold water when mixing. As for the level the silver probe on boiler.
Oct 08, 2015 | Astoria Coffee Makers & Espresso Machines
I replaced the pump and it's working, however, when I turned on the machine and the boiler came up, there's a stream of pressured steam coming out of releasing through the top of the machine. Any id
Hopefully, your pressure gauge is working, and if it is at 1.2 bar or so, then you have a failed anti-suction valve or boiler safety valve.
The ASV is the smaller fitting; it might be stuck, so you could try tapping the little button. The boiler safety valve is another matter - it will open at some point past 1.8 bar, which means the pressurestat is shot or its adjustment has been tampered with.
25401838-vippk3d42tdcmss1ngrlvpy2-1-1.jpgBoiler Safety Valve
It's most likely the ASV - they do get stuck open as well as closed...
Feb 05, 2015 | Astoria Argenta SAE-2 Espresso Machine
Pump intermitently turns on for 1 second when not busy
It is the automatic water level control kicking in due to turbulence in the boiler, but if the machine is neglected, the AWC probe is encrusted with scale, and must be cleaned or replaced.
Jul 29, 2014 | Astoria Argenta SAE-2 Espresso Machine
Gloria two group Astoria was shooting steam the other morning we turned it off what could this be from?
Where is the steam coming from, if its from the top, then the problem is the vent valve or the safety valve, if it is the safety then the pressure stat needs to be replaced because it might be damaged or blocked at the tube that connects it to the boiler.
Mar 12, 2011 | Astoria Argenta SAE-2 Espresso Machine
My 2 group astoria over steams from top of boiler.it warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Mar 23, 2010 | Astoria Argenta SAE-2 Espresso Machine
How do I program an astoria SAE-2 espresso machine?
Look behind the right steam valve, you will have to remove the front top panel, there might be a small toggle switch, note the position. If switch is not there then it is on the black CPU box. Press the program/stop button if all lights come on move forward if not then move the toggle switch to opposite side and press program button.
When all four lights are on press a button when you get the desired volume press stop, continue until buttons are programed then move toggle back to original lock position.
Sep 28, 2009 | Astoria Argenta SAE-2 Espresso Machine
Astoria SAE 1 trickle of water from hot water faucet
Some models have an economiser valve, which mixes hot water from boiler with cold from inlet line, that could be closed or obstructed. The line from the boiler to the solenoid or the pipe inside the boiler could be blocked.
Mar 20, 2009 | Astoria Argenta SAE-2 Espresso Machine
Hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
Astoria Argenta SAE-2 "Big Gulp" Logo
214 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
noel
noel
J.D. Browning
J.D. Browning
Kolbrun...
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
