Question about Diamond Multimedia Viper HD 2600 XT, PCI Express Video Card
Counter strike source loses monitor signal and sound stutters, but the rest of the system is still working as I can hear the hard drive, LAN port and model activity lights blink. diamond ATI hd 2600XT 256mb. xp pro 2 gigs ram pc-6400 800mhz athlon le-1640
    Guru:
  • 1,738 Answers
Replace your cable from the video card to the monitor.
Posted on Nov 20, 2009
Im trying to set up the game counter strike source but when I download it and click on it it brings me to a website called steam and doesnt let me play?
You need a steam account, all you have to do is sign up with Steam (which is free). However, if you have downloaded this game, chances are it may not work because majority of steam users actually download their games via steam (they pay using a credit card, and are then able to download a fully certified legal game).
I would suggest signing up for a Steam account and trying to play. If that doesn't work, there are a few ways you can by pass it.
ONLY playing LAN games is one. (Or in this case, pretending to only play LAN games.)
You can do this by:
1. Downloading Garena, Hamachi or Leaf. These are programs that let you play LAN games. (Supposed LAN games, because actually you're playing internationally, just like if you were on a console, but you are tricking the PC to thinking it's a LAN game, as well as fooling the game itself.) I would suggest downloading Garena as it works really well and has the major mainstream PC games. (Plus it is easy to use.)
Just go here:
http://www.en.garena.com/main/
They will give you instructions on how to download Garena, create an account, as well as other information you need.
Hope this helps!
Jan 30, 2010 | Electronic Arts Counter-Strike: Source for...
SAMSUNG SMO-211QN SECURITY SYSTEM
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
Computer monitor is blank. No signal is received at any time. Currently using motherboard VGA port. I tried 2 different monitors and 2 different VGA cables. I then installed a new graphics card but still...
Disconnect all PCI Cards and unplug power to all Drives then reboot your computer using the motherboard VGA port to see if the monitor will POST. If you still have a blank screen you most likely have a bad motherboard.
Nov 27, 2009 | Computers & Internet
you might need to lower your video quality down a bit, or upgrade your Graphics card.
Adding bots to the game uses logs more memory and graphics power, how does it play online?
Apr 17, 2009 | Electronic Arts Counter-Strike: Source for...
Help
Signal lost usually means the cable is lose that connects the monitor to the back of your computer.
with the computer off and unplugged , disconnect the monitor cable from the video port on the back of the computer and physically inspect the pins to make sure they are not bent on the monitor end.
some monitors have the same plug on both ends , so it doesn't hurt to check the monitor side of the cable.
Once the cable has been checked, if the cover is off the computer, i would check all cables and add-in card to make sure they are fully in thier slots and ports.
check memory for the same issues.
If your monitor is a multi-function device , make sure you didnt forget to hit the source button on it , could be on the wrong input.
Oct 23, 2008 | E-Machines eMachines Desktop PC
ACER ASPIRE 3690-2940
check the display on the external monitor by connecting it through the vga port of the laptop, check whether the display is coming or not, if coming then its the problem of your screen
Oct 14, 2008 | Acer Aspire 5100-5022 Notebook
No Real Time Sound from USB Port in Headphones
The problem is due to the design of the DELL Laptop itself. It is not dsigned to monitor the incoming signal. I bought a cheap Behringer UCA202 USB-Audio Interface. It provides for real time monitoring the incoming sound. I can also hear the accompanying music while I play along with pre-existing tracks. It's not the highest quality but it was only 25$ so well worth the price.
Oct 18, 2007 | Compaq Presario Notebook
Laptop Boot Problem
It seems all Compaq laptops are infected by this problem. If you are sure that the AC port and the AC adapter is working? Can you hear the laptop trying to boot? ..e.g. Hard Drive spinning up, Floppy Disk Drive noise, etc.. if so ...Try hooking up a external monitor.. Does it smell like anything has burnt? (Call for service) Is there anything that sounds loose when you shake it? (Call for service or you can to open it?) Try booting your laptop from a bootable floppy if you have one. Or use Compaq's Recovery CD. But I doubt if you use recovery CD, you might lose data on your HDD. Which O.S. are you using? The Boot-up mechanism checks all the hardware before starting Windows. Some times floppy drive doesn't allow the laptop to boot further by either not responding or sending wrong signal.
Jan 16, 2006 | Compaq Presario 1200XL104 Notebook
Diamond Multimedia Viper HD 2600 XT,  PCI Express Video Card Logo
98 people viewed this question
Top Diamond Multimedia Computers & Internet Experts
David
David
Lawrence Oravetz
Are you a Diamond Multimedia Computer and Internet Expert? Answer questions, earn points and help others
