Question about Samsung Jet S8000 Cell Phone
I have left my battery out for about ten monutes to fifteen and my samsung exclaim will still not turn on
My Samsung Exclaim M550 died and wont turn on. I have the charger in and the slide keyboard is lit up but It just wont like charge. Any help?
Have you tried pulling the battery out f the device? The reason I ask is because the fact that your keyboard is lighting up, suggests the device is powering on, but not displaying anything.
Try to pull the battery, then start the phone again. See if anything comes up. If nothing comes on the screen, but the keyboard is still lit, try calling the phone, does it ring? If it does, you can assume the display has gone out.
Instructions for pulling the battery attached.
Perform soft reset Samsung Exclaim trade
Feb 24, 2016 | Samsung Exclaim M550 Cell Phone
My samsung galaxy tab 2 the biger one is all screwed up on the screen its all rqinbow and like th eresolution is wack plez help
Hold down the power switch until it shuts completely off then wait ten to fifteen seconds and turn it back on. That should correct the screen issues.
Nov 02, 2013 | Tablets & eReaders
Front turn signals work but flash fast, nothing works in back lights at all
pull the positive wire of your battery wait bout ten to fifteen secs put it back on this will reset your computer
Feb 09, 2013 | GMC Sonoma Cars & Trucks
My samsung exclaim's screen is white and isn't showing anything
This is an ongoing issue with the exclaim. The most common fix for this, which may only be temporary is to, while the phone is turned on, remove the battery. This is called a soft reset of the phone. When a phone is simply turned off, the settings are left as they were. think of this as a computer freezing. You cant just put it in sleep mode to fix it, you need to completely reboot it.
Also keep in mind that as long as there is no water damage (shown in red on the the small circular sticker under the battery cover) this phone is covered by a one year manufacturers warranty. This would get you a FREE replacement vs. the equipment protection plan which would run you $50 dollars to replace.
Aug 25, 2011 | Samsung Cell Phones
My Samsung Exclaim cell phone will not turn on if not plugged in. When it is plugged in, it turns in for a minute then shuts off
Your battery may be completely discharged. Leave it plugged in overnight, and try in the morning. If that doesn't help, try with another battery or charger.
Thank you
Jan 25, 2011 | Samsung Exclaim M550 Cell Phone
It doesnt turn on just the screen samsung exclaim when plugged in
Might need a reinstallation of the software which might require the help from Samsung service to install a authorised version.
Sep 29, 2010 | Samsung Exclaim M550 Cell Phone
My car anti-theft seems to have kicked in and I can't get it to start. What do I do next?
hi, you can perform the reset with just your key and a battery charger to see if this will allow for restart. what you do is, hook up a battery charger to start with, low amperage setting like 15 amp, or maybe 2 amp, and leave it on the battery, you will be leaving the key on for up to an hour and the battery must not die during this time. turn the key on and try to start once for about 1-2 seconds, then let go and let key rest in run position for fifteen minutes at minimum. then turn off the key, wait ten seconds, and turn on again to run position only, leave on for another fifiteen minutes, then again, turn off for ten seconds, turn back on to run position for fifteen minutes. after this time, turn the key off, wait ten seconds, and try to start the car. if it starts, check to see if the check engine light is illuminated, or the security light is on, if one or the other is on, take to a shop and have codes checked and diagnosed, if no lights on, you should be able to drive on. if the vehicle does not start after three reset key cycles, try the process one more time. it may have been interupted somehow. if you try twice and still no start, you have to have diagnosed further, maybe in the key, maybe in the lock cylinder, maybe in the theft module.
Jun 30, 2010 | 2000 Buick Regal
Power Problem Samsung Exclaim
You can try running the battery completely dead and then recharging, but it sounds as if you have done that already. I would recommend purchasing a new battery as it sounds like it is dead.
Apr 03, 2010 | Samsung Exclaim M550 Cell Phone
My Samsung reclaim keeps shuttin off
try taking out the battery for five minutes
Nov 11, 2009 | Samsung Exclaim M550 Cell Phone
Samsung Jet S8000  Cell Phone Logo
76 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
