Question about SNK Navtour G4 4 GPS Receiver
I lost all my maps in my nav tour g4 how do i get them back?
I wish a free download for maps on my sat nav
Sat Nav - Free Downloads at CNET Download
download.cnet.com/s/sat-nav/
Download.comResults 1 - 10 of 1697 - sat nav free download - TV Remote Controller (ARM/XScale), Virus ... Includes detailed instructions, with maps and street view images of.
upgrade sat nav maps - How-To - PC Advisor
www.pcadvisor.co.uk > ... > How to update satnav maps
Dec 17, 2013 - How to update satnav maps: TomTom, Garmin and Navman charges ... purchasing, you are entitled to download it and update your device for free. ... when i bought my Garmin, there were roads both new and old that were not ...
MapFactor GPS Navigation Maps - Google Play
https://play.google.com/store/apps/details?id...mapfactor.navigator&hl...
Rating: 4.5 - ‎736,227 votes - ‎Free
Jan 05, 2016 | GPS
I formatted my garmin sat nav which deleted everything off they sat nav how do i reload all new maps back on it. I downloaded all they new maps but can t get them to go on sat nav now
If you formatted it while it was attached to your computer, this means you've also deleted all the unit's software plus the maps. You'll need to send it in to Garmin to restore the original software, and there will probably be a service charge for this.
Sep 11, 2011 | GPS
Garmin nuvi 1300 Query
Usually they come preloaded with some maps and you purchase additional ones. Check the manual that came with it or the box and that should tell you which ones it has. Generally speaking a basic unit bought in the UK will come with UK & Ireland preloaded, more expensive unit may have UK, Ireland & Europe and the most expensive may have all three plus USA. It's unlikely you will have 'lost' your USA map. The unit should have a 'drop down' menu which allows you to choose which map to load. Hope this helps!
Jul 26, 2010 | Garmin nuvi 1300 Car GPS Receiver
I've lost all maps & I cant get the sat nav to reset or give me the screen to tap in any postcodes
You need to update your Operating softvare. Go to a service or contact me.
May 19, 2010 | MyGuide 3100 GPS Receiver
Maps Nav-Cam 7000
try mininova.org or the pirate bay
Good Luck
Jun 08, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Lost map
Use the map cd that came with it and it allows you to remove and add the on the cd
Jun 05, 2009 | MyGuide 3100 GPS Receiver
Nav cam 7000
I have an SD card with original maps on it.
Mar 23, 2009 | Navigator Evesham Nav-Cam 7000 GPS...
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Nav-cam 7000 re-installing maps onto new sd card
.map files u can go website also dl all latest ones with resent fixes and firmware update to unit also ok thx nick
Feb 06, 2008 | Evesham Nav-Cam 7700 GPS Receiver
SNK Navtour G4 4 GPS Receiver Logo
200 people viewed this question
Top SNK GPS Experts
Robert Struzinski
Are you a SNK GPS Expert? Answer questions, earn points and help others
