Question about Master Bilt Master-Bilt MPM-72 7.9 Cu. Ft. Medium Temp Open Display Merchandiser
The coils freezes up frequently. Most recently,
The coils freezes up frequently. Most recently, w/in 3 days; before it took months. The defrost timer clock hasn't worked over a year I think. It stays in the same time as I leave it in. Do I just need to replace it with a new defrost timer?
  • Master Bilt Master
  • 43,501 Answers
If your defrost timer is not working then you will have problems with freezing the coils. When it is humid out and you are in and out of the unit the problem will be worse. To eliminate this problem you will need to get and install the timer. Do a search for "appliance parts" and checkout a number of the suppliers as the prices can vary a lot. All you need to find your part is the model # and sometimes serial# of your unit.
Posted on Nov 19, 2009
Coil freezing up
Hello if you have to defrost your evaporator coils every month then you problems are (1)defrost timer(2)defrost heater (3) blocked freezer drain or many;(1) check the defrost timmer so see if it is working the defrost time is from 15-25 min depending,And durning this defrost time you may hear the sound of ice melting on the heater a sine that the heater is working .(2) Blocked freezer drain,The water from the defrost cycle sitting in the drain pan,Is being picked up by the fan pulling it with the air back through the evaporator coil a second time freezing quickly ...
Jul 08, 2012 | Samsung RS2578BB Side by Side Refrigerator
Frigidaire side by side model # FRS20ZRGW3 coils freeze up on freezer side, fridge side gets warm
You have a defrost timer behind the front kick plate turn it clockwise slowly until compressor and fans stop. Once this happens the timer should remain off for 30 minutes and the defrost heater should come on during the first 15 minutes. If after 30 minutes the defrost timer part=> 215846602 Defrost Timer Assembly should come out of defrost and the compressor and fans should restart, if not advance the timer clockwise until they start and replace timer. Try that first and tell me what your results are. If that is not the problem then we can narrow this down to the defrost heater=> 218657301 Defrost Heater or 5303917954 Defrost Thermostat How to test the defrost heater is found on same page as the defrost heater. If you have any questions I will be here to help you, Thanks Sea Breeze
Apr 22, 2012 | Frigidaire Refrigerators
Frost free freezer keeps frsoting up. It's a french door refrigerator with the freezer on the bottom. The vent is not blocked. The door has not been opened frequently. The appliance is only 9 months...
Sounds like a defective defrost timer
If its a frost free upright freezer and the evaporator is frosting up with a snow like frost you have a defrost problem.. defrost themostate, heaters, or timmmer
Also note that
Dirty condenser coils are not the problem. It's most likely the defrost timer or defrost heater. The heater should come on about 3 times per day to melt the ice on the evaporator coils. If the defrost timer is not turning on the heater or the heater is burnt out, the coils will freeze up......
Hope this helps
Jul 28, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer keeps freezing up and the coils are totally covered with frost. We have to use a blow dryer on it about every 4 days. Sometimes it will last about a week. My husband took the protectoive cover off...
Your defrost system is out check 1 Defrost timer is it cycling. You can put it in defrost manually in the center of the timer is a dial youi can turn with a screwdriver slowly until the fridge shust down then look see if the defrost heaters are coming on. 90 percent it is thew defrost thermostadt it a small round part ussually located in the top left of of the coils jump that and see it the heater come on. replace any or all three the fridge should come back on itself after 30 min if the timer is working.
Apr 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
American stytle samsung f/freezer iceing up on fridge section
Sounds to me like a bad defrost control or a clogged drain line to remove the water after the defrost cycle has ended so the water just freezes again!
Aug 25, 2009 | Refrigerators
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
It just quit after a couple of months of very little use.
Most likely you have a defrost problem. When you unplug it for a couple of days, it thaws out and you plug it back in and it works until it freezes up again. Possible problem ...1 of 3...defrost timer...2 of 3...defrost heater...3 of 3...defrost bi-metal.
Apr 01, 2009 | Hotpoint 21.7 cu. ft. Side-by-Side...
Samsung French Door Refrgerator - New
Only two months old? Couldn't you complain to the store?
The way the defroster works is this: There is a defrost timer under the refrigerator. (I'm guessing based on other brands.) That turns on the defroster about three times per day. The defroster is a heating coil with the freezer coils. It heats that until the defrost thermostat gets warm; then it quits defrosting.
My guess is that the defrost thermostat doesn't turn off the defroster... that it continues defrosting until the defrost timer turns the defroster off.
So if you want to fix it yourself, dig into the defrost coils. I don't know where to look on a French Door refrigerator. Find the defrost thermostat, an inch wide unit with two wires. Test it for continuity while it is warm. There should be none. Frozen there should be continuity.
Hope that helps.
Jun 13, 2008 | Refrigerators
Leave to cool in the area of refigerador
If there is frost on tube going to compressor, either there is to much charge gas if recently recharged or the freezer is not defrosting as it should and needs to repaired. This usually follows with the freezer not freezing food correctly. If so the defrost timer or defrost heater coils are at fault. The timer is under the unit, the heater coils are attached to the freezer section evaporator coils which heat during the defrost cycle to thaw out the coils completely. Unplug the unit and let it defrost completely and the plug it in and see if the problem returns in the first day. If not, but returns after a day or two, then the problem is in the defrost circuit. This is not hard to figure out if you can use a volt ohm meter, but should be done by a technician since getting into the panels can be tricky....
Feb 15, 2008 | Refrigerators
Refrigerators Logo
70 people viewed this question
Top Master Bilt Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Master Bilt Refrigerator Expert? Answer questions, earn points and help others
