Question about Mtd Garden
Have a 1986 lawn chief tractor, its been sitting for 10 years.have a new battery but the solenoid just makes a buzzing noise when i turn thr key to the start position. I have change the spark plug, installed a new magneto and plug wire, changed the oil and put in a new air filter
  • 486 Answers
Sometimes when a battery is low or connections at the battery are dirty, you will hear a click,
that is the solenoid activating, but the battery voltage is low enough that the starter will not turn.
Sometimes this condition has a chatter.
Easiest test for this situation is jump start from you automobile, or charge the battery for an hour,
and see what happens from there.
Posted on Nov 19, 2009
  • 472 Answers
Ck the ground wire make sure its geting good ground or you may have a bad solenoid
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Tractor will not turn over even with new battery
try taking the spark plug out and spinning it over, it your still not getting anything does it even make a noise when you turn the key if your hearing a click and nothing else you could have locked up motor, a bad starter solenoid, or a bad starter, let me know what happens
madminibiker@gmail.com
M.Woodring
Apr 19, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My yard machine tractor does nothing when I turn the key. The battery is new. However the tractor is 12 years old. Could this be the alternator?
If it does nothing when you turn the key then replacing an alternator will not help. Numerous things could be causing this condition. I will try to cover a few. Make sure your PTO for the blades is disengaged and the clutch pedal is depressed. Make sure your battery voltage and all connections are good. Also make sure it is hooked up correctly. There is a fuse, usually near the solenoid, you need to check that. If all the above is good check to see if you have voltage going to the solenoid: There is a small wire that hooks to a spade terminal, you need to have 12 volts on this wire when the key is in the start position. If you do not, then you need to troubleshoot your safety switched. If you have 12 volts, then you may have a bad solenoid. Good luck, hope this gets you in the right direction.
Feb 17, 2011 | Yard Machines 155 Torque Briggs Stratton...
I installed a new solenoid, new battery, new spark plug. checked all my connections. and all i get is a clicking noise when i try to start the motor. could the starter be bad ? would it make that clicking...
Good morning Brian.
You need to have a current tester to make sure. If you don't have one, you can buy a cheap one for less than $10 that will get the job done.
1. Test the battery. Make sure you have at least 12 volts DC across the terminals. If not, charge the battery and retest. Even new batteries can be discharged or defective.
2. Test the voltage at the solenoid. You need at least 12 volts to each of the terminals when the key is engaged to the start position. You may need a helper to turn the key while you test the current. Failure to get current to the lower terminal on the solenoid is usually caused by a defective ignition switch or a defective/dirty safety switch. Most mowers have at least 3 safety switches. Your clicking noise is probably the solenoid engaging and is a normal noise.
3. Test the voltage at the starter. You need at least 11.2 volts at the terminal on the starter motor. If you have enough current, and the starter is still not spinning, then you have a bad starter. Sometimes a failing starter can be used a few more times by lightly tapping on the side of the starter motor with the wooden handle of a hammer. If the brushes in the starter are sticking, then tapping on the side will occasionally allow the starter to work. This is a very short-term repair. The starter will either need to be rebuilt or replaced.
Good luck.
Oct 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Attempted to start poulan lawn tractor, it begin to turn the engine over but immediately stopped cranking and the battery was making a fizzling noise. I installed a new battery and when connecting the...
Most likely you have a short in the ignition (key) switch. Disconnect the battery first! Then look at the wires behind the ignition switch for burned or missing insulation. If all that looks OK, I would replace the ignition switch. It is also possible that your solenoid/starter assembly has failed and the solenoid has stuck in the 'on' position; but that will cost more to replace so I wouldn't start there.
Aug 16, 2010 | Garden
Engine won't crank on a 18.5hp 4000. I checked mechanical interlocks, charged battery and put in fresh gas. New carb and fuel lines put in last year. When I turn the key, there is a click and the ammeter...
The starter solenoid is most likely the clicking you hear. It has contacts inside which go bad. These are about $10 and easily replaced. Just follow the + battery cable and it will lead you to the solenoid.
Jun 05, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I was riding the tractor mowing shut it off to get lunch returned 1 hr later would not start. I bought a new battery and had the starter checked all good still wont start. I get a click when i turn the key...
The starter solenoid sounds to be bad. Follow the + cable from the starter and it will lead to the solenoid. This is usually about $10. The battery produces power to the solenoid which then produces power to kick the starter over. The clicking is the contacts in the solenoid you are hearing.
May 17, 2010 | Yard Machines 155 Torque Briggs Stratton...
I have an 18.5 Intek Craftman Tractor. The battery
pull the plug out and crank it over....if it's been sitting, there's liquid fuel in the cylinder...can't compress liquid...drain the carb too...use fresh fuel...
Apr 18, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
May 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
259 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
