Question about Panasonic Lumix DMC-FX7 Digital Camera
Every time I turn the camera on it runs through it's warmup and then says please turn camera off and then on again. I do this and the same thing happens. When I turn it off it shuts down and then the lense retracts and comes back out before shutting down. Help!
  • 75 Answers
SOURCE: when switched on the camera
Make sure you are using the right kind of batteries. Not just the size (AA for example), but also check to see if the device needs Lithium batteries rather than Alkaline, for example). This can cause the issues that you see. Check your user guide for details.
Posted on Jun 20, 2008
  • 11967 Answers
SOURCE: turn camera on, lens goes in and out then camera shuts off
Is it possible that at one time, the camera automatically powered off to save the battery. In this state, the press of any button starts it back up again. If while in this state, you put the camera in a case and the lens tried to open, the force may have caused your problem.
Posted on Aug 28, 2009
  • 11967 Answers
SOURCE: cannot focus and shuts down
This message appears when force has been applied to the lens. You may need service.
Posted on Nov 14, 2009
  • 11967 Answers
SOURCE: Panasonic DMC-TZ4 When I switch on I get
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 20, 2009
  • 11967 Answers
SOURCE: shuts down when zooming
Posted on Apr 17, 2010
How to set the date and time
Keep calm, dear.
Please moderate your language.
Look in the manual for the instructions.
Jul 24, 2017 | Again and Again Cameras
Camera turns on, lens cyles (in and out) 3 times, then camera displays a message "Turn the power off and on again" superimposed on the display. Image is not in focus and camera will not take picture, just...
This is lens mechanism problem and lens assembly will be replaced to fix the issue.
Lens tries to correct its mechanical error three times then gives up and you see turn power off and on again display in lcd. If camera is under warranty, please call Sony to get it fixed or take camera to local camera repair shop if its out of warranty.
Thanks.
Jun 13, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
When I turn on my camera it says Access and after a few seconds it says turn on and off. When I do that it does the same thing over again
Hi there, Please confirm before power on the camera that, your battery is fully charged. If yes then remove the memory card & turn on the camera. Hope that time your camera working properly. Some time virus infected memory card not allowed to turning on the camera.
But with out memory card if the same problem happens then reset your camera or visit Sony service center. Because your camera operating system is corrupted and need to reinstall it again.
Thanks & waiting for your further quarry or feedback.
Feb 13, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
1990 Honda Accord LX Stalls everyday on warmup after it stalls it takes like 5mins for it to start up again after that it runs good for the rest of the day. then the next morning i go through the same...
Check and Clean the Fuel system from the Gas tank, fuel pump, fuel filter, injectors and plugs. Then check the idle control sensor and fuses. Fix any finds and should be good to go,
Oct 13, 2009 | 1990 Honda Accord
Hard starting will not restart after warmup
Try this: The next time you run the trimmer, and it begins to die, loosen the gas cap. It should start running again. This means that the gas cap is clogged. Clean the holes out of gas cap, or buy a new one. (If this doesn't help, give a more detailed explanation the next time.)
Jim
Jun 05, 2009 | Husqvarna 28cc Gas Line Trimmer
Fuel problem
You have carburetor issues my friend, take those things apart and clean them. Probably time to rebuild them if they have never been apart yet.
Mar 23, 2009 | 1997 Suzuki GSX 600 F (Katana)
Date & Time will not stay current
same thing happened to me too! lol. However after you press the menu button and click "default setting", go set your date and time again. Then turn the camera off. Turn it back on and you will find that the date/time is correct!
Jan 03, 2009 | Polaroid i1035 Digital Camera
Camera keeps turning on and saying high camera temp( camera will turn off)
Have you tried replacing your battery? Since it is a few years old, that may be the issue.
Apr 23, 2008 | Kodak EasyShare One Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
22 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
