Question about Sony KP-53HS10 TV
Need to replace the flyback (transformer) is it
Need to replace the flyback (transformer) is it easy to self-fix ?
    Scholar:
  • 86 Answers
Good morning friend. it is not very complicated to fix, but it is far more better to allow someone with experience to solve this problem. there will be excess solder on the bottom of the circuit board the connects the flyback. you must desolder this in order to remove it. you need to have a mesh desolder wick in order to completely remove the solder. go over each eyelet( pins from flyback) as many times it take to completely clean it. follow the cords to their different destination and unplug them. write down each location and what you did and go into the reverse order. thank you and pleasew rate my solution.
Posted on Nov 19, 2009
Tv dont come on but have a clicking noise, the led blinks with a click
I have a Samsung 32" that did the same thing a few weeks ago and I am still trying to fix it. The problem is the Main Flyback Transformer is blow with an open circuit in the Primary Winding that means you'll get no Picture. I also found the Power Transistor that feeds this Flyback Transformer was also shorted between terminals Collector Base Emitter(CBE). I bought a replacement Flyback but didn't work so now I need to get the Original part & it's not easy to find. Always use Original Components NOT replacements. Simply put if you're not technical I suggest take the TV to your nearest repair agent but be prepaired to pay for it. Cost of Flyback around US$50 & $10 for Transistor & if you find an honest repairman it should cost around $150 to repair otherwise it's not worth it. Good luck
May 30, 2010 | RCA 32F531T 32" TV
W to replace the flyback transformer on an RCA rear projection tv
Go to www.tvrepairworld.com you need the 270125 flyback kit listed under the RCA repair kits. The flybackk comes with the CD with step by step instructions.
Apr 06, 2010 | Televison & Video
Doubles on everything
run the auto-convergence option, if this doesn't fix it, you probably need to resolder the flyback transformer, and replace the middle of three fuses next to the flyback transformer.
Sep 18, 2009 | RCA HD52W59 HDTV Projection Television
Phillips 60pp9202 high voltage transformer
You can get the HV Transformer at the following link for 132.00 which includes free shipping and free step by step instructions by online instant messaging so you can easily replace the part yourself. Very easy repair. The HV generator is listed under the flyback section yours is Phillips 32942 Flyback ( HV Transformer)
Heres the link.
http://servicemanuals.vstore.ca/
Aug 01, 2008 | Philips 60PP9202 60" Rear Projection...
My TV keeps turning itself off
Try resoldering the flyback transformer. Thats a common fault if that doesnt help you may need a replacemeny flyback, as thats the number one fault with that model is the flyback wearing out. If you need more assistance let me know
Jun 17, 2008 | RCA HD52W59 HDTV Projection Television
Could I possibly have a bad flyback transformer
I would try resoldering the flyback connections on the Circuit board. if the flyback was defective it would operate and you usually get 3 blinks on the LED indicator. Sounds more like a solder issue.
Jun 15, 2008 | RCA R52WM24 52" HDTV Projection Television
Flyback Transformer
Yes you can get the replacement flyback which is flyback 259296 at the following link and they provide free tech support to do the repair . Its a very easy repair takes about 20 minutes and requires the very basic soldering skills. heres the link.
May 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not stay on.
Hello....
This problem is related to ABL control .
Trace ABL signal from Pin no 11 of flyback transformer.Mostlikely value for the resistor in abl line has gone high.First case reduse the G2 voltage and see if the unit works for long.
Second case its sure that its ABL problem.
Nov 20, 2007 | Sony KP-51HW40 51" Rear Projection...
Flyback transformer on television
Single white line across screen mean a vertical colapse. So you will need the vertical output and maybe a cap around 100uf@50v.
Sep 13, 2007 | RCA E13320 13" TV
Sony KP-53HS10 TV Logo
313 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
