Question about Buck Chevy Hhr 2006 Radio Stereo Wiring/wire Harness Plug
The sound on the radio on my 2006 is going out the lower volume doesn't work but the louder volume does
  • crnbread73 Nov 19, 2009
    we did that and still nothing. it was going out like when a radio station fades out and comes back in and then it started doing it with radio and cds now it the lower volume has went out all together and only works when it is turned up i had to adjust so that sound comes from back speakers so that it doesn't blast me out of the car
  • 364 Answers
Sounds like a fading problem, adjust the equilizer to balance the fade. Good luck
Posted on Nov 19, 2009
  • wayne
    wayne Nov 19, 2009
    is this an original stereo or aftermarket? if aftermarket there are 8 wires for 4 speakers, all 4 earth wires must remain individual from the others do not intertwine them together . Alternativly it may be the banks in the unit dying, they cost as much as the stereo sorry.
The volume is noticeably lower when listening to the radio. It sounds normal on CD, Aux and MP3. I know it has a built in amp. Could this be the issue. Thanks.
You have not mentioned what type of radio you have, what car it's installed in, and what other audio equipment you have. I will assume it's an aftermarket radio, and it's common that the tuner's signal strength is not going to be as powerful as the other sources. If the built in amp is used, then it's used all the time, with all sources, including the tuner. Some brands will have a loudness offset function wherein you can lower the power output of the CD/Aux/MP3 inputs to volume match the radio, but there's no fun in that. There's not a way to make the tuner play louder, unfortunately, aside from adjusting the volume when using the tuner section. Technology has brought many advances, including a much higher signal to noise ratio, which is why digital trumps analog in this instance. This is what you are experiencing, which is not necessarily a technical issue, but a technology issue.
Jul 02, 2017 | Car Audio & Video
The sound is screeching when the volume is louder
that screeching is called feedback..which is caused by loop oscillation in plain english that means that sound is going from the speaker to the microphone and "looping" causing feedback noise or "screetching" there is nothing you can do but lower the volume it's a normal phenom not a fault in the product but more user error. sorry to say. the only thing you can do is lower the volume till it goes away.
Dec 12, 2013 | JBL On Stage Micro Speaker Dock for Apple...
How do I change radio volume on the alarm?
This clock is supposed to have an automatically "increasing" volume feature (starts off low, gets louder over a minute or so).
If not sufficient, look on the top right side of the clock, there should be an up/down volume control. It is a black oval-shaped button with a picture of a sound speaker in the middle. Push it upward to increase volume and downward to decrease volume. Unfortunately, you have to have a flashlight or light on to see it because none of the controls are illuminated.
Dec 02, 2013 | Sharper Image Sound Soother White Noise...
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
My volume on the xm radio band is noticeably lower than the regular fm band. Is there anyway to adjust the volume on the xm band tto make iy louder?
XM radio usually has lower volume than regular FM/AM bands. But there 'might' be an adjustment you can do with your radio, depending on your unit. Please indicate the brand and model of your radio so I can check.
Sep 24, 2011 | Car Audio & Video
Radio on VW Jetta shorts out
This is most likely a bad ground from the radio to the chasis. The louder you play it the more current it draws and the lower the voltage drops thru the resistive (bad) ground. When volatge drops below a certain point the radio shuts off.
May 29, 2009 | 1998 Volkswagen Jetta
2006 ultra radio has no sound
This is a very common problem with this radio there is a part in the radio that controles volume and it breaks down after a period of time due to vibration... If you need any repair help you can email me at HRmotors@aol.com I no these radios inside and out and would be happy to help you- thanks
Jan 13, 2009 | Harley Davidson 426290 AM/FM Radio
I need my volume to be magnify
You need to know what operating system your PC use. This is a simple steps to make more louder the sound in Windows XP system:
  1. Click [Start] menu, choose [Settings] and then click [Control Panel], finally chose [Sounds and Audio Devices]
  2. On tab [Volume] od Sound and Audio Devices Properties, move Device Volume Control slider from "Low" to "High" position.
  3. Click [Apply] at lower right most corner part of the panel
  4. Click [OK]
  5. The volume has become louder
Note: I think, adding a pair of stereo active speaker is the simple way instead of getting more louder sound of the PC's sound card.
Nov 26, 2008 | Computers & Internet
Buck Chevy Hhr 2006 Radio Stereo Wiring/wire Harness Plug Logo
221 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
handygirl911
handygirl911
Steve Sweetleaf
Steve Sweetleaf
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
