Question about Smeg SE399X/5 Stainless Steel Electric Single Oven
Shut down after 10 minutes
The oven completely shuts down after about 10 minutes. Then, after about 5 minutes it turns itself back on, but only lasts another few minutes before shutting down again. This happens when using all settings, including the grill.
  • whywhwhy Jan 24, 2008
    I'm not sure if it's reaching the correct temperature or not. Sometimes it stays on for 10 minutes and sometimes it's only a couple of minutes. Sometimes, after switching itself off a few times after about 10 minutes, it will actually work fine for another 30 minutes. I had the grill on for 2 minutes the other day before it switched off. Then sometimes it works fine. I've had the safety switch replaced, but the problem persists.
It is reaching the correct temperature and then switches back on when cools a bit?
Posted on Jan 24, 2008
Cannot open door after cleaning. Buttons are not responding to a touch
Silly answer but have to ask.
Have you unplugged the oven for 10 minutes to reset it?
Mar 27, 2016 | Ovens
Door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
Feb 28, 2011 | Viking Ovens
The fan continues to run. How long and will it automatically shut off?
The fan you refer to should be the fan in the oven cavity. It removes hot air from the oven cavity and expels the air out the front of the oven. Once the oven is turned off the fan will continue to operate until the oven cavity has cooled sufficiently. It may run for 10 to 15 minutes and will turn off by itself.
Feb 12, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Why does the Oven take so long to light?
It sounds like it might be a sticking gas control valve for the oven or the hot surface igniter for the oven might be weak. You will need to turn the oven on and off completely several times until the problem happens. When I say completely I mean turn on the oven control and watch the igniter start to glow. Then when the oven burner comes on(should within a minute) shut of the oven control and wait for the igniter to stop glowing completely and burner to shut off completely. Then repeat the process again. If you try it about 10 times and nothing happens then the problem will be difiicult to identify. If you turn on the oven control and the igniter comes on but the gas burner does not then try giving the gas control valve(located in brolier/storage compartment) a tap with a wrench. If the burner suddenly comes on then the control valve was sticking. Try repeating the shut down/turn on process again. If it does not do it again you may have fixed the problem...if it does you will need to remove the igniter and test it with an ohm meter(should read at least 500 to 800 ohms). If the igniter is testing good and glowing brightly then the gas control valve would be the suspected problem. And remeber to be very careful when doing these testing procedures so you do not hurt yourself.
Nov 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Thermador oven timer doesn't repeatedly chime for 5 minutes anymo
I just fixed my timer! Press and hold the OFF button for 10 seconds (until you hear 1 chime). Thanks to David at Bosch/Thermador!
Nov 17, 2008 | Thermador SC302T Electric Double Oven
Kenmore wall oven model 911.4088816
www.kenmore.com/shc/s/s_10154_12604_Kenmore_Cooktops%2C+Ranges+%26+Ovens_Wall+Ovens
Try to identify which oven you have and try to get a manual from the same source
Feb 03, 2008 | Ovens
Oven shuts off?
F34 is a cooling motor fault. May sure that the cooling motor is running.If not, then check that there is 120 volts to the motor.The motor sensor on this oven is attached to the cooling fan. It could be a simple issue of loose wire in the connector. Find the wiring going to the relay unit from the motor, pull the connector and hold a flash light on the back side of the connector. You should see almost no light. If you see mostly light, there is your loose connection.
Jan 06, 2008 | Thermador SEC301BPSS Electric Single Oven
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
F7 SHOWS UP ON THE SCREEN
this problem just occured to me last nite. we had to shut the power off at the breaker box. we turned it back on this morning and it seems to be working fine. it is still a mystery as to what occured but it appears it had to reset itself. not sure if this is a solution, but it has appeared to be working so far.
Nov 23, 2006 | Kenmore 33464 / 33465 / 33469 Gas Single...
Smeg SE399X/5 Stainless Steel Electric Single Oven Logo
357 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
