Question about Samsung SGH-i900 Omnia Unlocked Cellular Phone
My touch screen started acting all funny...i was typing a text msg and if i pressed a letter, two letters down would engage...then it stopped working all together. buttons work fine but no screen...had not been dropped, exposed to water, or extreme temperature. very strange
Daughter borrowed phone and switched the text msg typing to auto fill and numbers. I have tried every thing and I can't figure it out, can you please help me? Thank you, Susan
Based on your description, what you are referring to is called T9 Predictive Texting. It allows words to be entered by a single keypress for each letter, as opposed to the multi-tap approach used in the older generation of mobile phones in which several letters are associated with each key, and selecting one letter often requires multiple keypresses. Example, when typing the word 'love' in a T9 activated phone, all you have to do is press the numbers 5, 6, 8 and 3 once in sequence. As compared to the regular texting, in order to complete the word 'love', you have to press the number 5 thrice, the number 6 thrice, the number 8 thrice, and the number 3 twice.
If you want to disable T9 predictive texting, it can usually be disabled by pressing and holding the hash or number key (#).
Hope this information is helpful.
Apr 08, 2011 | LG Cell Phones
I get the letters msg on the bottom of my 42inch lg plasma why is this
Menu, Special, Software update....2 choices Manual and auto
Put on manual and you start getting MSG at the bottom of the screen.
Put on auto and it stops.
Andy
May 20, 2010 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
My sumsung SGH-E250 FREZZES SOMETMES WHEN SWICTH IT OFF AND BACK ON THE LETTERS BECOME UPSIDE DOWN.
the problem can be solved.The phone has two fault:
the freezing of the phone
and
the upside down letters.
The freezing the phone is caused when there is virus infection on the phone or there is an application that is affected.
The phones memory has been corrupted and it needs to be restored by flashing the phone.
And for the upside down letters, when the flex of the phone that is connected to the front board that makes the screen display has cut, it starts to display funny letters. So the flex of the phone needs to be replaced with another one for those funny letters to stop.
Take care and good luck.
Mar 17, 2010 | O2 Samsung SGH-E250 Cellular Phone
How to get my lg neon on touch screen texting
ok so i might sound really stupid because the lg neon's keypad is for dialing only but yesterday i was like pressing a bunch of buttons on accident and like letters came up on the touch screen and like i pressed the end button to see if it will go back to normal and now i cant get it to get lit to text on the keypad i cant even believe it did it and it was totally by a mistake has this ever happened to anyone?
Jan 08, 2010 | LG Neon GT365 Cell Phone
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
I have never sent a text msg before. I am in 'create msg', and when I press a number, a whole string of letters appear...I thought it would scroll through them,and I would stop when I get to the one I...
here the t9 dictionary is turned on..when it is turned on,u just enter the first letter of the word and it will display the possible words starting with that letter...u can turn off that by pressing #. or from the options ,select input method and turn off the t9 dictionary..
Oct 21, 2009 | Nokia Cell Phones
Recently my blackberry storm has been acting very odd...it started out when i was typing and i wanted a different word and i try to tap on the word that i want..it would highlight the top and the third but...
Turn off the UAC by completing the following steps:-
  1. On the computer, open Control panal and select User accounts.
  2. Click Add or remove user accounts.
  3. Select the account to be changed, and then click Turn user account control on or off.
  4. Check that the Use user account control (UAC) to help protect your computer option is not selected.
  5. Click OK.
Oct 19, 2009 | RIM BlackBerry Storm 9530 Smartphone
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Phone freezes when trying to type a txt msg
Do you have too many text messages stored on your phone? I had a phone like that, If when I neared the storage limit it would stop allowing any entering of text messages. Just go to the menu button when your in the text message area and press the menu key, scroll down to cleanup messages, select it and delete them all.
Nov 12, 2006 | Motorola Mobility RAZR V3
Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
95 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
