Washing machine wont drain - Washing Machines
    Sergeant:
    Champion:
  • 289 Answers
Nead to know what bran.
Posted on Nov 19, 2009
Washer wont drain. fills with water. goes through wash cycle but wont drain. once it gets to the spin cycle, it spins for a few seconds and then stops and rinse light comes back on.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | GE Washing Machines
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
Maytag Neptune washing machine - wont drain & spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing machine wont drain F03 message is
heatman101
May 15, 2010 | Frigidaire ATF6000ES Front Load Washer
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
The washing machine wont drain out , but will
Could be , you could remove pump and put two wires onto to check but be carefull Electricity kills..Could also be feed to pump from machine,Check 1st nothing is sticking blades , which is most likley
Oct 03, 2009 | Hotpoint Ultima WF860 Front Load Washer
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
