Question about Sony DAV-DX250 System
Protect unplug I'm having a problem with my home theater sistem that as soon as a turn it on it came out the phrase protect unplug i need your help please what should i do................
  • 10,594 Answers
Dear ecuabling,
Sony Home Theater system gives such message at that time when it gets problem in Amplifier section. You should contact nearest Sony repair center for better solution.
Posted on May 27, 2008
  • venkyspai Jul 04, 2011
    Hi, I am facing same Protect Unplug error with my Sony Home Theatre DAV DZ-10, can you pls. let me know the part no. of the IC that needs to be replaced.
Samsung HT-TZ312 shows "protect" and it turns off
A short on the speaker wires can cause this but most likely your amplifier bias is off or you have a shorted transistor.
First unplug all connections, even the power. Let it sit for a minuit then power it back up.
If it clicks off them it needs professional service.
If it turns on inspect all of your speaker wires for shorts them reconnect them one at a time.
Hope this helps,
Cheers
Feb 03, 2010 | Samsung HT-TZ312 Theater System
Protect Unplug
I know that almost all new equipment since 99 or so on up has these. They are too sensitive. This is a system program that will put stereo in protect mode when turned up loud or have a lot of bass on to stop from blowing audio outputs.
Aug 07, 2009 | Sony DAV-DX250 System
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 23, 2009 | Sony DAV-DX250 System
"protect" on the screen
Bad speaker wiring.
Internal fault.
Regards.
Jan 18, 2009 | Samsung 650W 5.1-Channel Home Theater...
Need help
I think, your Home theater gives you error message " protect unplug", means home theater has problem in Amplifier section and will not be power up to function.
You should check Amp section aspacialy Amp Output stage.
Jun 04, 2008 | Sony DAV-DZ100 System
Protection Problem on Samsung Digital Home Theater
Bad speaker wiring.
Internal fault.
Regards.
Apr 14, 2008 | Samsung HT-DS610 System
Protect
The protect message indicates a problem was found inside the amplifier. The output transistors are most likely shorted and need to be replaced. This is a fairly simple repair and should cost about $40 in parts plus your local labor charge.
Dan
Mar 18, 2008 | Sony DAV-S500 System
Sony DAV-DX250 System Logo
546 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
