Yes it's painful... Manufactures and vendors FIX the items that have THE MOST complaints, but often build in NEW problems with devices that worked before!
TRY going back to a older version(s) first... ESPECIALLY true if your device worked BEFORE the latest update... HERE is a GREAT Site for you and others:
I have the same problem and do not know the answer. Was searching here for an answer to my problem. Only a small part, 4 tracks in fact, about 5 minutes from a 30 minutes tape are imported to Itunes. where is the solution because it seemed the computer was recording the whole tape without problem. Where is the data gone. Can someone explain. Nico
I've had exactly the same problem, and so far no resolution from Ion. A small bit of good news: the .wav files are on the hard drive, although without any track info. At least on Vista, they are in username/AppData/Local/Temp. The files are name Temp0, Temp1, Temp 2, ...
You can use iTunes to add these files (File/add file) and then convert them to .mp3s, or whatever format you prefer. Or you could convert them first using the tool of your choice, such as Audiograbber.
This is inconvenient, but a lot better than re-ripping the vinyl after EZVinyl hangs.
it sounds like EZ A C did not get the audio or EZ put it in a format tha Itunes Cant play. download VLC media player and install it. open the file with VLC and se if it will play it. It will play just about anything it has most of the codex's need to play anything too. if it doesent play it then something is wrong with the input to EZ A C you might have the input muted.
Try Control panel -Sounds - click on Speech and Audio Devices - Click onSounds and Audio Devices. or if your in classic view -double click. Click on Audio tab
Make sure that thedefault devicefor Sound Playback is set to the device hooked up to the speakers
i.e. set it to something other than the USB AUDIO CODEC which is the turntable
