Question about GE WBSR3140DW Top Load Washer
MY GE washer will not stay filled it just keeps filling and draining.It will not go on with the cycle but, I can move the dial and it will act like its draining and go through the spin cycle.
    Sergeant:
    Champion:
  • 289 Answers
Make sure drain line is vented.
Posted on Nov 19, 2009
GE washer wont stop filling with water
If your timer dial doesn't advance and it just keeps filling sounds like a bad timer.
Dec 14, 2013 | GE WDSR2080D Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
My top load washer after the washer fills with water and starts the cycle it stays at the agitte stage. have to move the dial to drain and then move the dial to rinse etc. is this the cycle dial that has...
It sounds like the timer motor has gone out on your timer and you will have to replace the timer itself. If you get the model number and go to www.sears.com you can pull up a diagram of your unit and order the timer for it.
Jul 22, 2009 | Washing Machines
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Dial
Guest, you got it right but this is typically not a problem on whirlpools now because the drain exits at a higher level. however if its the older with drian exit at bottom then definately make sure it goes up then down to avoid gravity drain.
adjusting the dial to fix indicates a potential timer issue. is the drain pump running (spinning) while filling?
Mar 15, 2009 | Whirlpool Inglis IP4400 Washer
Washer won't spin and keeps filling
one thing is wrong is balance.That's why it knock the wall down.Don't know to much about GE.But I would check the dasher to see if it's down.But the belt could be broken under the washer.
Mar 13, 2009 | GE WSKS2060WWH Top Load Washer
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool filling and washing, not draining, rinsing or spinning
Check out your outlet filter, probable it is clogged. Clean this out and refit. Most cases when the drain or spin does not work, it is the filter. This is a suggestion.
Apr 01, 2007 | Frigidaire FWS833A Top Load Washer
GE WBSR3140DW Top Load Washer Logo
95 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
