Question about Water Heaters
I AM REPLACING A FLUSH URINAL WHICH HAS A TRAP CONNECTED TO A TRAP ADAPTOR.THE NEW URINAL I AM PUTTING IN IS A WATERLESS FLUSH FREE URINAL.THIS URINAL REQUIRES A BRASS URINAL FLANGE BOLTED TO THE WALL WHICH THEN THE URINAL COUPLER (SUPPLIED WITH URINAL)BOLTS TO THE FLANGE INTURN SQUEEZES THE FOAM GASKET (PROVIDED) BETWEEN THE URINAL FLANGE AND COUPLER ENSURING A PROPER SEAL. HOW DO I INSTALL A BRASS URINAL FLANGE TO AN EXISTING DRAIN WITH AN EXISTING 1 1/2" TRAP ADAPTOR GLUED ON WHICH HAS A P TRAP CONNECTED TO THE EXISTING URINAL.
    President:
  • 704 Answers
Hello, First you'll have to remove the existing glued trap adapter from the drain pipe, just behind the P-trap. You may have to cut this off with a hand-held hacksaw to keep as much of the drain pipe going into the wall, as possible. You may have to open up the wall to get more access to the drain pipe, if possible. Each installation has it's own issues, depending on where and how it was installed to begin with.
Then you'll have to add a glue to threaded adapter to the drain pipe (at the wall). That will allow you to screw on the waterless brass flange to the PVC pipe (with the new threaded adapter.
I'm not certain as to what the diameter of the drain pipe you've got going into the wall, but you can always get the correct adapter for joining the pipe to the brass flange in your kit.
Here is a link to a brass flange for a waterless urinal that should be similar to what you're using. Basically, you just need to make sure the clearance and measurements of the rough-in meets the specs for the new urinal that you're installing. So double check everything before you glue the threaded adapter on and dry fit the pieces first, so you have the ability to make any changes that might be needed to accomplish your retrofit.
http://www.plumbersurplus.com/Prod/Waterless-5001-Urinal-Flange-6011-Mounting-Hardware-and-G-208-P-Gasket-Kit/31431/Cat/1172?utm_medium=referral&utm_source=googlebase&cvsfa=63&cvsfe=2&cvsfp=31431
I hope you find this Very Helpful and best regards!
Posted on Nov 19, 2009
No hot water coming out from this waterless tank
Humm.....is there ANY water comming out at all???? If so, it sounds like an electrical issue. If not, check fot a blocked water line, or the unit itself may be clogged. If you have hard water, the lines may be full of corrosion.
Feb 18, 2015 | Water Water Heaters
I drained tank but it still makes rumbling sound
The sediment that can build up in the bottom of a water heater can actually harden the popping sound your hearing is from the water that is trapped under the build up. when your heater fires the water under that build up has no where to go so it turns to steam so the popping sound is that steam bursting through the build up. If flushing it didn't help the only way to stop it would be to get a new heater
Jan 05, 2014 | Bradford White 50 Gallon Natural Gas Hot...
NEW WATTER HEATER MAKES A HUMMING /WHISTLING SOUND
Factory-installed heat traps can cause this problem:
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
Remove heat traps, or heat trap inserts, or heat trap nipples.
Make your own heat traps, and save 4-9$ per year, using flex copper connections, or reconnect pipes in heat-trap configuration.
Always insulate pipes.
With electric heater, pipe insulation can run all the way to tank.
With atmospheric-vent gas water heater, the pipe insulation cannot obstruct air intake at draft hood. With power vent gas, the pipe insulation can run all the way to tank.
Mar 10, 2013 | Water Heaters
After plumber flushed out my gas water heater the valve where he connected flush hose leaks. 1st only a few drops, but now a dinner plate size puddle. It never leaked before this. I had the flush done
Put a brass garden hose cap over the dripping drain valve.
Call the plumber.
Absolutely the plumber should take care of this for you since the cap has to be tightened pretty tight.
See illustration:
http://waterheatertimer.org/images/drain-with-cap-500.jpg
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
Comment back and let me know what happens.
Oct 01, 2012 | Water Heaters
No water being dispensed from my Insinkerator hot water tap following insallation of new filter
Probably debris from old filter got trapped in the line.
If the insinkerator has aerator, take that off and flush out debris.
Otherwise, the line will have to be taken apart and blown out.
Aug 11, 2012 | Water Heaters
Do I need to use the heat trap nipples on my new Rheem electric hotwater heater, I am pressed for space Thanks
Rheem residential electric water heaters appear on following page:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
New water heaters are made with heat trap nipples pre-installed so the product meets industry energy standards.
Sample Rheem manual says: 'All models equipped with heat traps.'
http://globalimageserver.com/fetchDocument.aspx?id=052c9e32-ce37-48d7-8990-9e430f23fef3
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 31, 2011 | Rheem 38 GAL ELEC SHORT Water Heater 6YR...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Water Heaters Logo
54 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
