Question about Whirlpool LER4634J Electric Dryer
My dryer doesn't have any power. How do I fix it?
    Sergeant:
    Champion:
  • 289 Answers
First,nead to know what bran it is.next check the braker.
Posted on Nov 19, 2009
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
Dryer vent was cloged now heat dosent work
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-200-865057-/LG-Dryer-doesn-t-heat-DLEX2501V
Sep 01, 2014 | LG dlex2501v front load steam electric...
My fridgidaire dryer (gas) stops functioning throughout a timed cycle - I then reset the dryer timer and it doesn't want to operate again. Other than calling a tech to come fix the dryer, what t
Probably the motor behind the knob. I replaced mine in a Kenmore recently. No big deal for someone with average skills. Go to washer/dryer forums. Lots of them. This will have a ton of solutions. Try YouTube
Aug 06, 2013 | Dryers
Dryer doesn't shut off and doesn't get hot
Look at this video to help you fix the no heat issue.
Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool Dryer LE7800XKNO doesn't work!
It is not hard to fix at all. Does it run and heat if the belt was on?
Nov 04, 2012 | Whirlpool Dryers
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
Pf keeps coming up wont run
if you haven't tried this,unplug the power or shut the circuit breaker off for 15 minutes,this may reset the defaults on the unit,if this doesn't help,then shut off power to the unit and open up unit and disconnect each and every connector to check for poor conduction,then reconnect power,if this doesn't help then replace the c.c.u. central control unit
Apr 20, 2012 | Kenmore Elite Oasis 6809 Electric Dryer
Frigidaire dryer doesn't produce heat, but everything else is working. What do I do to fix that problem?
Unplug remove panels necessary
Check the element for breaks or issues
if no problems found replace the safety devices directly in line with the power supply for the element
Nov 15, 2011 | Dryers
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
