Question about Car Audio & Video
How to build a sound box by 15 inchess speaker of 600 watts
    Problem Solver:
  • 7 Answers
What sub? And what volume do you need? First off you will want to go get yourself a sheet of 3/4" MDF, nails, resin, etc. You'll also want access to a table saw and drill. Decide how much volume you need and then settle on some dimensions to achieve that volume.
Posted on Nov 20, 2009
Need box specs for Alpine dvc type r 2ohm 12"
  • frequency response: 24-200 Hz
  • power handling: 300-600 watts RMS (300 watts per coil)
  • peak power: 1,800 watts
  • sensitivity: 85 dB
  • top-mount depth: 6-3/8"
  • sealed box volume: 0.65-1.25 cu. ft.
  • ported box volume: 1.0-2.0 cu. ft.
  • Crutch field audio has a DIY section on box building ;)
Oct 20, 2014 | Car Audio & Video
Audio speakers
Have you installed Kicker capacitors? With the extra power you have you will need them to help with the load.
Jan 28, 2014 | MA Audio Car Audio & Video
Recommended enclosure for maxp154d
Send me the type and model of vehicle it is going into. From there we can determine what type of sub box to build.
Jan 31, 2012 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
15PLB76 15 Inch 800 Watt Woofer Car Speaker: what subs will be good to fit in my gmc sierra sin...
single shallow with a sealed box it would sound great!! no air tombs they **** thats called ported they really ****
May 17, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
How much air space
Air space needed around the sub is a minimum of 1 inch, but 3-7 is preferred. If you get too big you can get an echo sound. Sealed is my preferred box - it generally gives you the deep base thumping you are probably looking for.
Hope this helps! Rate my solution!
Jan 05, 2010 | Boss Blade BL240DVC Subwoofer - 15" Dual 4...
15" Lanzar 400 watt sub
you would have to build a ported or sealed box with a sloped back
Sep 19, 2009 | Lanzar OPTI1222D Car Subwoofer
HOW TO INSTALL
I would say look for a custom box off ebay or build one behind rear seat. Im not shure if you can fit a small truck box behind there but you may be able to. It would sound pretty good behind rear seat. Hope this helps
Jan 13, 2009 | Pyle 12" 600 Watt Amplified Subwoofer Tube...
Gem Sound clipping problem
First of all the EXA-3940 is rated at 350watts per channel in to 8 ohms. The 1400 watts is bridged into a 4 ohm load. Second, the speakers can handle 1000Wats peak with an average of 600 continuous (i'm guessing). That tells me that the amp is underpowered for the speakers. The sensitivity of the amp is such that the mixer is overdriving the input stage. That is what is causing the clipping. If you are looking for more volume, you are probably better off purchasing another amp and running them in bridge mode, 1 per speaker cab. Be careful though, not to overdrive the speaker cabinets either.
Dan
Sep 21, 2008 | Gem Sound GemSound PA-585 2-Channel...
2 12" Hitron 600w subs in a BandPass box
Remember that driving a load with an underpowered amp will probably cause more problems than having a more powerful amp that is not running flat out. 200-300W amp would be ok, but I would suggest going for the biggest you can afford. If you crank up the volume on the smaller amp you will probably get a fair amount of distortion, which may actually damage the speakers. A larger amp will not give as much distortion for the same loudness/volume and give better control of the speakers for a tighter bass..
Oct 31, 2007 | Hitron 2 12in Subwoofers loaded in...
Car Audio & Video Logo
149 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
