Question about Zanussi ZT485 Built-in Dishwasher
Whirlpool dishwasher dishwasher does not seem to fill up, goes through cycles, clean light flashing at end of wash, soap has not dissolved ( liquid soap), heating element smells very warm turning white
  • zman303 Jan 12, 2008
    Yeah you can hear it surging
  • 75 Answers
Hi there sounds like your wash pump may have burnt out can you hear the water trying to surge when in wash mode ?
Posted on Jan 11, 2008
Fills with water and drains does a few times goes thru complete cycle but washer never washs, water does not spray dishes. Soap dispenser opens.
1st check for food build up under the filter, just shine a flash light through the holes front left side at the edge of your filter. This area is the water intake for the wash arms.
Oct 25, 2013 | Whirlpool 24 in. GU3200XTP Built-in...
I have a kitchenaid dishwasher that doesn't dissolve even liquid soap. At the end of the cycle there is hard compacted soap residue that ends up blocking the holes where the water shoots out and there are...
Try getting some calcium, lime and rust remover. Follow the instructions on the bottle and run the dishwasher empty using only the CLR. Check your incoming water lines for calcium or lime build up.
Sep 17, 2013 | Dishwashers
My dishwasher is not cleaning my dishes. at the end of the cycle there is still liquid in the dispenser.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 13, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Oct 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Liquid soap mistakenly used - bubble explosion
Fill the detergent cup with fabric softener for a full cycle. Don't be alarmed if bubbles seep out.
Finish off with a white vinegar wipedown of the insides if it still feels soapy.
Sep 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The soap packet doesn't dissolve, it remains intact at the bottom of the machine at the end of the cycle.
don,t use those packets stay with powder or liquid dishwasher soap. the packets need a lot of heat to dissolve,.
May 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Suds coming out of the front
When you have suds rolling out of a dishwasher, you can assume that either that one of the dishes was loaded with liquid soap or that the dishwasher soap dispenser was filled with liquid, manual wash soap or laundry detergent.
After the mess is cleaned up, the quickest way to clean the dishwasher is to start up a new cycle, wait for the hot water to fill the dishwasher and just as the DW starts to pump the water through the spray arms (wash cycle) open the door and poor in two cups of white vinegar.
Hope this helps!
Apr 04, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
GE Portable Dishwasher won't fill/cycle
In a front corner of the tub is a float switch that raises up as the machine fills, then shuts the water off. when pumping water out the float drops and enables the fill solenoid valve to work when signaled by the timer circuit. Make sure the float is free to rise and fall. The residual soap may be holding the float up. Run some cycles without soap to clean the tub, manually clean it out if necessary. Make sure the water supplied to the machine is at least 129 degrees to get good cleaning and prevent soap build-up.
Sep 04, 2017 | GE 24-7/8" Convertible Portable Dishwasher...
Filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
Hello chystalsbrr
Welcome,
You said you, filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
You can try by turning off the breaker in the electric box that feeds the dishwasher for 5 minutes and see if when you turn it back on and the washer resets itself, and the soap door opens.
Or push cancel and then rinse and after it is done and goes to the dry cycle stop it and it should be open.
In the use of liquid soap in both a dishwasher and or washing machine you must use less soap. Half that of powder soap.
Or the suds will roll out of your dishwasher on to your floor. And this is not a malfunction on the dishwashers part. NO bad seal or anything!
In a clothes washer it will destroy the seal and bearing in less than 5 years!
Let me know how it goes!
Huuum
Please remember to leave a rating
Oct 19, 2008 | Whirlpool Dishwashers
Soap does not desolve
check that the spray arms are turning and that the holes in them are not clogged, if you line them up pointing towards the front let the machine fill then as it starts to wash open the door and you should see the arms slowing down, if they are okay then check the water level which should just lap the filter at the bottom
Jan 07, 2008 | Jenn-Air JDB6510 Built-in Dishwasher
Zanussi ZT485 Built-in Dishwasher Logo
161 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
