Complete refrigerator will not get cold - Washing Machines
    Sergeant:
    Champion:
  • 289 Answers
Nead to know what bran it is,also nead to know if ther is ice or frost forming on the back wall in freezer.
Posted on Nov 19, 2009
What if the refrigerator side is not getting cold and the freezer side has a lot of lce on back but does not get that cold eather
Completely defrost your freezer and then plug it back in. A lot of fridges get there cold air from a vent connected to the freezer unit and that could now be blocked by ice. Your cooling coils also won't work correctly once they are covered in ice. So completely defrosting it and letting is sit open for a day or so to get the ice completely melted out of the vent and cooling coils should fix the both problems.
Mar 17, 2014 | Refrigerators
Refrigerator not cold enough and freezer is too cold making food very hard? water seems to leaking on bottom of freezer and refrigerator.
Refrigerators with attached freezers typically keep the two compartments at predetermined temperatures, but failure of some components can lead the refrigerator to seem warm while the freezer portion completely freezes.
Fan Issues
According to the appliance website Appliance Aid, many freezers contain a fan that blows cold air throughout the freezer and into the attached refrigerator. If this fan fails, the site explains that the freezer may become too cold; the refrigerator will not receive air circulation from the freezer, though, and will remain warmer than normal.
Air Damper
Appliance Aid also notes that most refrigerator and freezer combinations contain a damper that regulates the flow of air between the two compartments. If the damper sticks or fails to function properly, it may restrict the flow of air from the freezer to the refrigerator. The result of a failed damper would be a completely frozen freezer and a warmer than normal refrigerator.
Hope this would help.
Good day!
Sep 06, 2011 | Kenmore Refrigerators
Refrigerator is not getting cold, freezer is cold but not completely freezing. Refrigerator is 13 years old
defrost problem, ill bet there is ice on the back wall of the freezer towards the bottom
Feb 21, 2011 | GE Refrigerators
Freezer is cold, refrigerator is not cold, also not cold enough for making Ice
See if the condenser fan motor underneath is running.Maybe completely filthy with dust build-up underneath refrigerator.May need to rake the coil.
Feb 07, 2011 | Kenmore Refrigerators
Not cold any longer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
987ryjh
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana SCD25tw side by side. Ice cream very soft, freezer blows semi cold air NOT ice cold. refigerator side seemes ok. I checked coil and it is NOT icy.
If the coil is not iced up then it is not a defrost problem but rather if the coils are not completely cold all over then the compressor is failing or the refrigerant has leaked out.
Sep 05, 2009 | GE GTS22KBP Top Freezer Refrigerator
Fridge stopped being cold and freezer not freezing
Switch off the refrigerator. Let all ice melt completely. it may take 4 hours. Switch it ON again. does it work better for 2-3 days. if yes,change bimetal and timer.
Aug 09, 2009 | Magic Chef CTB1821AR Top Freezer...
Freezer temp and fridge temp not as they should be
you should try and defrost the feezer completely as ice might be blocking the cold coming in. it happed to my fridge freezer and that cured it and it is working perfect now.
Jul 19, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer is cold. refrigerator warm no water in tray
evaporator fan motor is defective or the bimetal t-stat on the eveporator is stuck open not completing the defrost cycle causing the evaporator to frost up and not allowing the cold to migrate to the refrigeration section. so you have 2 things to check, also if your unit has a damper in the refer section it may be stuck closed not allowing bthe cold to migrate.
nbcrca :)
Apr 11, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Elite Stainless French Door Not getting cold
This unit may be frozen up.  Defrost completely to allow the passages to get a free flow of cold air.
Nov 16, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Washing Machines Logo
Top Washing Machines Experts
