Question about Fuji FinePix Z100fd Digital Camera
Focus Error When i turn on my camera, it makes a loud beeping noise, and the screen is black. When it finally shows the regular screen, when i take a picture it says I have a focus error. Is this fixable?
It's a message given when the internal lenses get jammed, possibly due to debris within the gears that move the focus. The "Focus Error" message can involve many FujiFilm models.
Posted on Jul 21, 2010
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
My Big Screen making a loud beeping noise!
The beeping noise is usually related to the Horizontal out put transistor or flyback being faulty or one of the coils are loose near the flyback. If you remove the rear cover without touching anything can you tell if the beeping is coming from the large transformer with the red wire coming out of the top or is it coming from a black transistor on a aluminum heat sink.
Jul 22, 2008 | RCA P52930BL 52" Rear Projection...
Red light, Won't focus, horrible loud wail noise.
if you love your camara bring it to a olympus dealer and ask them to check what the repair costs would be than uyou can decide to try it your self, buy a new one or let it be fixed.
Sand is always dangerous , it can come to vital parts where you don't want it to be.
cleaning yourself:
especially do not use a vacuum cleaner to suk the sand out, but , use enough light, a pair of steady hands, a box to fit in the screws (make a drawing witch srews where when) and take the time, use inside only a clean painters brush (thin) and wipe out any sand that can be seen, from the optics. than after cleaning assemble it in the reverse order of the disassembly , put all the srews in their place tighten them hand vast (not with a electroic tool but only by light force ) vast is vast (meaning it should use a light force to open the screw) and preferably use a dust free environment (rent a baby's box like in the hospitals used for very young childern)
but my advise would be advise nr 1: bring it back to the dealers
May 17, 2008 | Olympus FE-180 Digital Camera
Digital camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2007 | Cameras
Camera will not operate
Use the audio-visual cable that came with your camera and connect your camera to your TV.  Now turn-on your camera and switch to "view mode", e.g., to see a already taken picture on your LCD.  You will not see anything on your LCD but may see an image on your TV, even if the image is "F18".
I used the above trick to clear an F18 error on an A75.  Right now I am trying to get the camera to focus properly, but somehow the above cleared the F18 error.
If the above does not work, try connecting your camera to your computer's USB port using the other cable that came with the camera.  Your camera will want to be on, and in the "view mode".  I have read that this trick can reset an F18 error.
Good luck.  At least it costs zero to try these two tips.
Oct 11, 2007 | Canon PowerShot A75 Digital Camera
The camera zoom got jammed
This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 at my shop. Broken drive gears are generally This can be caused by several different situations. Most commonly the camera has experienced some kind of impact which knocks an element out of alignment, preventing the lens from rotating normally. Symptoms of this include: *you may hear no mechanical sound at all when the camera is turned on *you may see visibly mis-aligned components of the lens *you may hear a loud "snap snap" sound as the camera tries to move the lens when the camera is powered on The second most common cause is a particle of sand getting stuck in the focus motor drive gears. This prevents the focus element from moving normally and causes the camera to shut off to prevent damage to the lens assembly. Symptoms of this include: *A loud "buzzing" sound when the camera is turned on, followed by the beeping and shutdown. Finally the third most common cause of this problem is a broken tooth on the zoom motor drive gears. Symptoms of this include: *the sound of the running motor with a regular "click click click" sound for several seconds. This will not be a "snap snap" sound, that is a different problem. *the lens will move in and out easily by hand as if free from any resistance. All of these problems require disassembly to repair. The charge is around $125 labor at my shop.
Jun 14, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Lenc cover will not open
Jun 12, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera lens
Apr 29, 2007 | Canon PowerShot A510 Digital Camera
Canon Ixus 40
Apr 27, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
My Camera has E18 Problem
May 07, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Fuji FinePix Z100fd Digital Camera Logo
658 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
