Question about Jwin JD-VD522 DVD Player
Hello, I have a Jwin JD-VD522 player. All of my dvd's and vcd's have been playing properly except one I just ordered will not play. Now I contacted the company in which I ordered the VCD and they claim that they tested it before it went out and it played perfectly so I don't know what the problem is. They said try changing my player to PAL format, but my player is already region compatible meaning that it already plays PAL. I don't know what to do now. Thanks.
    Sergeant:
  • 269 Answers
Hi! i think the vcd format you have acquired is not compatible with your player format. ask the company where the vcd was purchased and ask its specific format.
Posted on Nov 19, 2009
My IBM R51 laptop can't read any other cd/vcd
its either its a lens problem or that was how the CD/DVD Drive was made.
There are some drives that doesn't play white face discs, that is, they select disc and don't play all CD's, so maybe yours fall under this category.
How long have you been using your laptop and has it ever played Cd/Vcd's before?
If it plays them before, then it means your drive's lens is weak, but if it has never played them before, then it means that's how the player was made.
Which ever way, you still have an option of replacing the drive if you wish.
Take care.
Apr 14, 2010 | HP Compaq nx6115 Notebook
My jwin model jd-vd509 does not play all regions,how can i change that? iwas given player in macau in macau as a gift,but find that the origanal dvd`s i bought in the uk and australia wont play,it comesn...
Don't know if it will work on your. I have a jWin JD-VD141 and the code works. Have the DVD tray open (means ejected) then press 9735. A menu will pop up and choose Regions 0 then exit. You DVD player should play DVD from all regions.
Dec 08, 2009 | Jwin JD-VD509
Problems with Jwin Electronics JD-VD138
I just found this answer from another contributor.
Turn the power on
Close the drawer
Press 9735
Select Region 0
Exit Setup
You now have a multi zone DVD
Jan 31, 2009 | Jwin Electronics JD-VD138 DVD Player
Dvd disc is not recognised after loading
i would like the code for this jd-vd141 dvd player
Oct 09, 2008 | Jwin JD-VD141 DVD Player
Won't play DVDs from asia .. need region code unlock.. help.
try with the disc tray closed. and if that doesn't work turn player off by plug socket and turn back on and start from the setup menu part of the unlock code after turning player back on.
Aug 22, 2008 | Jwin JD-VD135 DVD Player
1- Open tray
2- Press setup
3- Press 1 3 8 9
4- Use Up/Down key from remote control to change the Region
5- Press setup
Apr 03, 2008 | Jwin JD-VD135 DVD Player
TV plays color, dvd black and white
If I understand your post/description, the DVD plays OK except it is in Black & White. If so, change setting from PAL to NTSC or vice versa depending on the region you are in. US operates on NTSC, Most of Europe is PAL.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 19, 2008 | Jwin Electronics JD-VD138 DVD Player
Player Does not play any type of Disc
Press case lid where it attaches to player. If this makes unit react you have a defective lid switch. You can probably put some weight over it to hold lid down and it will operate. Otherwise switch must be repaired
Oct 06, 2007 | Jwin JD-VD149 DVD Player
Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Sep 21, 2007 | Jwin JD-VD149 DVD Player
JWIN JD-VD502
Sounds like a PAL/ NTSC problem which you must fix on either your TV input or DVD player output or settings. This should fix the problem if you alter the settings.
Nov 15, 2006 | Jwin JD-VD502 DVD Player
Jwin JD-VD522 DVD Player Logo
101 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
William
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
