I want priority scheduling algorithm in c++...
    Brigadier General:
  • 10,406 Answers
If I help you do your "homework", do I get a diploma or certificate or degree from your School?
Posted on Nov 20, 2009
Is this true?
If the documents were queued in order of priority, a no priority document could go to the end.
Jul 15, 2014 | Office Equipment & Supplies
What is the equation for finding pi?
Two algorithms were discovered in 1995 that opened up new avenues of research into pi. They are called spigot algorithms because, like water dripping from a spigot, they produce single digits of pi that are not reused after they are calculated. This is in contrast to infinite series or iterative algorithms, which retain and use all intermediate digits until the final result is produced.
American mathematicians Stan Wagon and Stanley Rabinowitz produced a simple spigot algorithm in 1995. Its speed is comparable to arctan algorithms, but not as fast as iterative algorithms. Another spigot algorithm, the BBP digit extraction algorithm, was discovered in 1995 by Simon Plouffe:
Nov 04, 2013 | Office Equipment & Supplies
Our teacher gave us a project about cpu scheduling, we need to create an application or program about the topic. The problem is he never discussed about cpu scheduling. I tried many research and read about...
Firstly this may be a bit over my head, but, i will try to help u.
CPU scheduling, is all about what the the CPU's priority's are .( Or tasks that come first.) Have you tried a block diagram. ie. a bit like a pyramid Ok got as far as MLQF then done a search on internet.
Well done good one..
Apr 12, 2011 | Televison & Video
When I try to record back to back programs on different channels the timers won't work. It tells me there is a conflict with the timers and tells me to change priority or whatever. I can set a manual...
Hi this is Luke.
DVR Priority settings are used to prioritize timers should there be a conflict between timers. The top of the list is the highest priority and takes precedence. The bottom of the list is the lowest priority. A lower priority timer will not fire if there is a higher priority timer at the same time. Timers that conflict with each other will display Attention 532. The message may display when switching from Single User Mode to Dual User Mode because the receiver recalculates timers for conflicts.
  1. Press DVR three times on the remote (twice for a 942 receiver). The skip timer icon (red x) designates a conflicting timer.
  2. Select Timers.
  3. Select Set Priority.
  4. Select the timer to change.
  5. Use the Up and Down arrow buttons on the remote or the Move Up and Move Down options on the screen to move the timer priority one at a time. Use the Move to Top and Move to Last options on the screen to make the timer top or last priority.
  6. Select Done.
Selecting Automatically resolve by priority will allow the receiver to set the priority level of the timer. The last timer created will have the lowest priority level and will not be recorded if both tuners are being used for other higher priority level timers.
Selecting Change the priority of this timer will allow the customer to set the priority level of the timer. With the new event highlighted in the Daily Schedule screen (the event will display with the skip icon), press Select. Select Restore and then Yes. The new timer will now have a higher priority level than the conflicting timers.
You may also want to resolve the conflict by:
  1. Press Menu on the remote.
  2. Select Daily Schedule.
  3. Select Timers.
  4. Arrow over and select the timer that needs to be edited.
  5. Select Edit.
  6. Make the desired changes then select done.
Let me know if this help.
Jan 21, 2011 | DISH Network DVR 510 DTV Receiver /...
My net speed very down why can you help me
QoS Packet Scheduler is a method of network bandwidth management that can monitor the importance of data packets and depending upon the priority of the packet, give it higher or lower priority or bandwidth levels. It's not very useful unless you're using apps which are QoS-aware or running a server, so you can gain some network overhead back by turning it off.
Note: This following tip will not work on XP Home Edition.
  1. Make sure you're logged on as actually "Administrator". Do not log on with any account that just has administrator privileges.
  2. Start > Run > type gpedit.msc (not available in home version).
  3. Expand the Local Computer Policy branch.
  4. Expand the Administrative Templates branch.
  5. Expand the Network branch.
  6. Highlight the "QoS Packet Scheduler" in left window.
  7. In right window double click the "limit reservable bandwidth" setting.
  8. On setting tab check the ENABLED item.
  9. Where it says "Bandwidth limit %" change it to read 0 (ZERO).
  10. Close gpedit.msc.
Effect is immediate on some systems, some need to re-boot.
Jan 07, 2011 | Office Equipment & Supplies
Question 1: Find out the reasons those have made the UNIX an amazingly successful operating system. What are the Features on existing UNIX based operating systems like Linux Red Hat, Fedora and Ubantu...
Question 4: Consider the following set of processes that arrive in the ready queue at the same time:
Process CPU time
P1 2
P2 1
P3 4
P4 3
P5 1
P6 2
Consider the following scheduling algorithms: FCFS, SJF and Round Robin (quantum = 1)
(i) What is turnaround time of each process for each of the above
scheduling algorithms?
(ii) What is the waiting time of each process for each of the above
algorithms?
Jan 06, 2011 | Televison & Video
How do i use my calculator on my sidekick
Hi friend,
You can find the calculator in the menu"Additional fuction" or just the menu"Calculator". Then you can start,there are many numbers and algorithm, you can imput the numbers and calculation rules according to priority.
Good luck!! If you have any other cell phone or notebook problems,you can visit our website:www.1010store.com
Aug 26, 2009 | Motorola Mobility SIDEKICK SLIDE Cell...
CPU Scheduling VB.Net Sample Program
well threading does this for you, look at the thread class and related classess in .net
Jun 02, 2009 | Microsoft Visual Basic .NET Standard 2003...
I want priority scheduling algorithm in c++ codes and java source codes
Do da fool 4 user enterd no. of students. Find da avg 4 a student of his marks in 3 subs print whether he passed or failed. A student wil fail if his avg<50. Use for loop given no.s
Mar 24, 2009 | Computers & Internet
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
