Question about HP Officejet 7130 All-In-One InkJet Printer
HP Office jet 7130
The machine kept giving a carriage jam error. When I opened the machine, there was a film tape that obviously connects to two metal springs on either side of the machine. I think it should go through the carriage somehow, but I don't know where. HELP!!!!!
    Problem Solver:
  • 9 Answers
That would be your encoder strip. It does thread through the carriage, attaching on the left to a spring metal tab, and on the right hooking onto a rigid metal mast. You can probably get a fair idea of the connecting points by visiting http://www.fatrcat.com/7100ss.html
Scroll down through the instructions to find the right area, and I can be contacted if you need more help.
Posted on Mar 12, 2008
Does the office jet 8500 have a power reset button ? paper jamed, i removed the paper but now nothing happens
Check the following Steps to fix HP Printer Carriage Jam :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Our HP Office Jet Pro 8500 printer has a message stating there is a paper jam when there is no paper jam. How can this be fixed?
Check the following Steps for fix Hp printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
My HP Officejet J4680 states that there is a cartridge jam. How do I fix this?
this issue is a little tricky as the unit may think there is a paper jam
first make sure the craddle - where the ink cartridge sit - can move freely, if it can then look for any bits of paper that may be stuck around it or in the machine, clean the rollers on the rear access door of the unit as well.
if the error message doesnt clear out then try the next step
If the carriage chute will not move then disconnect the power cord press and hold # 3 at the same time and as holding those 2 buttons re connect the power cord. if the carriage fails to move upon reset then you have a carriage jam and your printer needs servicing
Mar 29, 2010 | HP J4680 Office Jet All-In-One Printer
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Repeated "carriage jam" error, but NO real jam!
Here are two links from HP relating to Jams ans carriage noise.
You may have to copy them and put them into your browser if they don't open by clicking on them.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00618080&lc=en&dlc=en&cc=us&rule=20342&product=1119598
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00743863&dlc=en&product=1119598
Joe
Please remember to rate Techs who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 09, 2008 | HP Officejet 6310 All-In-One InkJet...
I have HP Office Jet V40. I changed ink cartridges. When I put the printer on, there was a message in the window, "Clear carriage jam, and then press Enter." I opened the door and had a good...
Open the lid and uplug the power cord, then reach in there and give the whole carriage a little boost one way and the other, my photosmart 8450 does this once in a while and once I move it a little and plug it back in, it goes where it should be.
Aug 07, 2008 | Office Equipment & Supplies
HP Officejet 7130 All-In-One InkJet Printer Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
