Question about Proform CrossTrainer Treadmill
My pro-form xp-680 platform broke that the belt cirlces around. The particle board with the smooth laminant on it. I need to find out where I can order a replacement.
  • 64 Answers
SOURCE: display works, treadmill doesn't
Motor controller.
Posted on Jun 08, 2009
SOURCE: we need a new control board for our pro-form 560
yes sounds like a contoller, if you need to order contact us through the web at www.AtlantaFitnessRepair.com
Posted on Aug 24, 2009
SOURCE: pro form service manual?
Please type in your model number on this page to get the free downloadable manual:
http://www.iconservice.com/proform/manuals.html
Hope this is helpful
Posted on Sep 12, 2009
  • 10865 Answers
SOURCE: I purchased a pro form 585 treadmill around 1999.
Hello. These proform treadmills are prone to the problem you have. Go to http://www.proform.com/ and contact customer support. They should send you free replacement parts as these white metal parts are prone to breaking. Regards, Joe
ps - kindly rate my anser as helpful. thanks.
Posted on Feb 16, 2010
roadtech7
  • 293 Answers
SOURCE: I have a pro-form 680
The walk belt should be tight (about 1.5" to 2 " when lifted at the edge), if not tighten screws at the rear. If the belt is tight enough then pull the front cover off and check the front roller. Sometimes the plastic drive pully slips on the front roller. If it only stops while you are running and is fine when you walk, i would go to the front roller.
Posted on Nov 03, 2010
I have a pro-form 680 lt and it will not come on
1) Test the fuse blown or c. breaker , replace or reset.
2) Test the key magnet,with the magnet of your refrigerator for to attract or repel, and replace if necessary from any Hardware store very cheap!
3) Lube the deck belt, very well.
4) Test the input voltage motor, if there are the motor need repair.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you.
May 24, 2012 | Proform Exercise & Fitness
Hi, my Pro Form 470cx has just started to stop when I walk on it intermitently. The belt is running perfectly until I stand on it and then it appears to stick instantly on the base causing a stall in the...
Susan,
The most common cause of belt slippage is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
Hope this helps.
Regards,
DIYpro
May 04, 2011 | Sport & Outdoor - Others
I have a pro form treadmill and it seems like the belt is sticking, its about 14 yrs old. I think I might need to replace the belt
kilgore511,
The most common cause of belt sticking or "slippage" is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
If you have found this helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
Apr 29, 2011 | Proform Exercise & Fitness
I think the belt needs lubricant. It's getting squeaky again.
I had this problem with a Pro-Form 1200 model and it drove me crazy as well. It was coming from the screws that secure the wood walking platform to the metal frame. Tighten whatever screws and/or bolts that secure the walking platform at the front two corners, or all four if they are loose. This solves the problem.
Feb 05, 2011 | Proform 810 TR Treadmill
I have a pro-form 680 LT less than a year old. The belt seems loose, it catches as I run and I about fall over.
Nov 02, 2010 | Proform 680 LT Treadmill
When walking on my pro form xp weight loss 620, while walking along fine, every so often it starts to make a slipping sound and seems like the belt is slipping. tried tightening the belt and still does the...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Jul 07, 2010 | Proform XP Weight Loss 620 Treadmill
Delamination
its not supposed to as there is not that much steam coming out if it does contact whirlpool and check your installation instructions
Mar 28, 2008 | Dishwashers
Proform CrossTrainer Treadmill Logo
126 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
