Question about Toshiba MK8025GAS 80 GB ATA-100 Hard Drive
Say's it needs to initialize and comes up with eisa.
  • aaronmburg Nov 19, 2009
    I tried what you said but it's like it's not turning on. I'm not hearing anything from the drive. The computer management in Vista see's it but it won't initialize. Hope I don't have to send it out. It looks like I probably will.
    President:
  • 2,600 Answers
The EISA partition is a partition that a computer manufacturer places on the disc to assist in recovery of that maker's files. It is not necessary to have this partition if you do not intend to perfrom a factory recovery. I will include a guide below to assist you in a deletion of that partition. To initialize a disc, it can be done ways, boot the computer and it will advise you the disc has not been initialized and will initiate a wizard to assist. I attach the hard drive to another computer using an EIDE/SATA to USB adapter, it will be recognized as an external drive but will not give it a drive letter because it is not initialized. You have to go to the control panel > administrator tools > computer management > disc management. Look in the right lower pane and it will show the drive with a grayed out box to the left, it may label the drive as drive 03 or 04 etc. Right click on the drive number and choose initiate. The computer will initiate the drive and give it a letter. It will also ask you if you want to initiate the drive as a bootable drive, choose yes. Below is the guide to delete that EISA partition so you can use the drive in any laptop you see fit.
EISA Partition Delete
1. Open a command prompt as administrator.
2. Run Diskpart application by typing Diskpart in the command prompt.
3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
4. Then type in list disk and press Enter key to show all hard disk drive available.
5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
6. Type list partition and press Enter key to show all available and created partition in the disk selected.
7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
8. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Posted on Nov 19, 2009
  • Chip
    Chip Nov 19, 2009
    If you right clicked in the right spot and it refuses or states that it cannot initialize the disc, then I would suspect the drive has died. I just had one do the same thing....Not much you can do, if you need the data bad enough, there is data recovery, that can be expensive to the tune of 1500 bucks in some cases. Depends on the capacity of the drive and how much data needs to be recovered. Good luck.
I am having VGN 23G and it came with Vista Home Premium. Right now im using window 7. The os's is working properly. Due to 1GB of RAM using vista is a bit frustrating . All the drivers for VAIO VGN 23G...
All the VAIO Computers will be shipped with the Recovery partition in the Hard Drive. If the Hard Drive is not completely formatted, you can access the Recovery partition by pressing the F10 key for 5 to 10 seconds when the VAIO logo appears.
If you're able to access the Recovery partition, then select Restore C Drive option to restore the Computer back to the factory settings.
Let me inform you how to check the if Recovery partition is available.
Press windows+R key and type diskmgmt.msc and check if you're able to view EISA partition. If EISA partition is there, then the Recovery partition is available and you can access by pressing the F10 key at start-up.
If the EISA partition is not there, then the partition is deleted, then you can purchase the Recovery Discs for your Computer which may cost $15 to $35.
Jun 22, 2010 | Sony VAIO VGN-N110G/W Notebook
Purchased new laptop Sony Viao Model No -VGN-C2 .I have 80 GB HDD.In that i got 8GB EISA Partition .And rest of the Other Partition is only C: Drive.So when i asked my dealer so he replied me that it is a...
Well there is an array of programs out there that can do this for you. I suggest gparted. If you download the gparted iso and burn it to a disk. You can boot from the disk and then you follow the onscreen instructions. You can divide the partitions in any way you see fit. If you have any questions on using the program you can always contact me and I'd be happy to answer
Nov 27, 2009 | Microsoft Windows Vista Ultimate Edition
Why hardware system may require the installation of new hardware components?
Well there's two reasons. One is that software keeps getting more and more complicated. The other is that with the new technologies come new standards that the old pieces don't conform to and therefore won't work with. I'll use graphics cards as an example.
In the beginning, the IBM PC/XT and its clones had 8-bit bus slots. This is where the video card (such as it was) would be plugged in. As time went by, 16-bit computing came to the consumer market with the advent of the IBM AT (Advanced Technology) and the Intel 80286 CPU. The 8-bit slots now were 16-bit slots called ISA. Fortunately, 8-bit cards continued to function in ISA slots but the 16-bit ISA cards outperformed them and so nobody wanted the 8-bit cards anymore. The same thing happened when the industry advanced again with the 32-bit Intel 80386DX and SX. The bus architecture changed to the 32-bit EISA which again was backwards-compatible with ISA. Things changed during the time of the 486 when the VESA standard appeared. It didn't dominate the market because it didn't have time to. EISA was already entrenched and just as VESA started to catch on, a familiar face appeared. The familiar face was PCI, it was introduced just before the original Pentium and was the fastest bus slot ever seen. The PCI slot dominated for awhile but computing got progressively more graphic intensive and the PCI slot couldn't cope because it is a shared bus (All the PCI slots on the motherboard share bandwidth with each other). AGP was introduced in 1997 (AGP 1x) and got progressively faster with 2x, 4x and finally 8x. PCI-Express v1.0 appeared and immediately offered double the bandwidth of AGP. AGP's days were now numbered. PCI-Express v1.0 was upgraded to PCI-Express v1.1 but even that was soon superceded by PCI-Express v2.0 which again doubled the bandwidth over PCI-Express v1.0/1.1. Although PCI-Express v2.0 is completely backwards compatible with previous versions of PCI-Express, it is not compatible with AGP at all which is why new cards were needed for motherboards with PCI-Express. This was true for EISA/VESA - PCI, PCI - AGP and now AGP - PCI-Express. The slot changed to accomodate new techology and so the cards had to change with it. Similar events occurred with every standard in the computer industry and new products had to be used to match the new and more advanced hardware standards. There's your one-time answer. :-)
Nov 17, 2009 | Computers & Internet
Acer boots from xp
take it back to store. basically a hidden, but unremovable partition is causing the xp bootup. It happened to me aswell. They will probably give you a replacement as it is an unfixable problem. Even with new hard drive didnt fix it. Sorry about that.
Mar 05, 2009 | Acer Aspire 6920 Notebook PC
I purchased new laptop Sony Viao Model No -VGN-C2 .I have 80 GB HDD.In that i got 8GB EISA Partition .And rest of the Other Partition is only C: Drive.So when i asked my dealer so he replied me that it is...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Symantec's Norton PartitionMagic 8.0 and Norton Ghost 10.0, they're both good Choices—but you can use any nondestructive partitioning utility and the backup app of your choice, of course. And all you need to do is create a partition that's large enough to hold your stuff; then back up your primary drive to the partition. If and when the time comes to restore, run Ghost and expand the backup image to your primary drive. Presto: You're back in business
For the best results, start with a fresh install of Windows, then load your applications, utilities, and drivers. Make sure to install all the latest updates as well, especially for Windows and your security software. Finally, tweak your system so it's exactly the way you like it: video resolution, wallpaper, the works.
Create The Partition
Fire up PartitionMagic (or a similar utility) and create a partition with enough available space to hold Windows and your apps. Ten gigabytes should be ample for most users (remember, the backup image will be compressed), but consider making it larger if you have a lot of programs installed or storage space to burn.
NTFS is the file system. As for the partition type, the active partition is the one that boots the system. You need to create a logical drive (that is, one you can assign a drive letter), which will live in an extended partition—the app takes care of that part.
Set Up Ghost
Run Ghost (or a similar utility) to create a new backup. Don't bother with scheduling, as this particular backup is a one-time-only affair. Disabling your virus checker prior to starting the backup is a good idea; AV can gum up the works.
Recover
To use the recovery partition, make sure you've backed up all your vital data to another drive or removable media, then boot your PC with the Ghost CD loaded in the optical drive. You'll then be able to restore from the partition to your primary drive, resulting in a ready-to-roll PC with all your apps, drivers, and settings loaded.
Jan 23, 2009 | Microsoft Windows Vista Ultimate Edition
How to Create EISA Partition...in Vista Or XP......
You can't. The partition was created by SONY to hold recovery files because so many people lose their installation disks. So SONY created the partition, loaded the special software on it and put options in the menu to use it.
Problem
Insert the recovery disk and re install windows.
Dec 14, 2008 | Toshiba Satellite A205-S4617 Notebook
Recovery
I would assume trying to press F12 or F10 or F9 when booting up. If you really need to know please refer to the owners manual if you still have it.
GOod Luck
Aug 21, 2008 | Computers & Internet
EISA configuration
I believe that he EISA configured partition is where your computer manufacturers 'Restore System' data is kept so that you can't normally access it and mess it up. You seem to have gone to a lot of trouble to do work around that.
I would be interested to know if you can still restore your system now using the data that you transferred to a different partition?
Nov 01, 2007 | Computers & Internet
Toshiba MK8025GAS 80 GB ATA-100 Hard Drive Logo
429 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
