Question about Durabrand Portable DVD
Power to second screen
When using these in the car, the second unit is not getting any power. Does anyone know where to get the connecter cord (one yellow end and one black end) that connects the two screens together? Please advise
  • acrick Mar 26, 2008
    I have the same problem, did you ever find a replacement cord and where?
  • 3 Answers
Try the online help at http:www.1800customersupport.com. Also, in order to watch both units together, once connecteded by the audio video cable (red/white/yellow), the power supply must go to the dc in jack of the monitor (not to the the player).
Posted on Mar 23, 2008
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
TO RESET THE UNIT
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Touch screen wont work
Try the following to bring the touch screen backto life.
Step 1:
Do a power flee by unplugging the power cord from the rear of the printer and holding down the power button for 30 seconds.
If the above doesn't resolve the concern, then try the step 2.
Step 2:
Perform a Full Reset of the HP Photosmart ,
-Press the On button to turn off the unit.
-Disconnect the power cord from the back of the unit.
-Disconnect the power cord from the AC outlet.
-Connect the power cord to the back of the unit.
-Connect the power cord to the AC outlet.
-Press the On button to turn on the unit.
If the touch screen has not gone bad,the above troubleshooting steps should resolve the issue.
Thanks and regards,
Techbuddy247
Jun 10, 2010 | HP Photosmart D7260 Printer
When I connect my Garmin Nuvi 200w to my car to charge it does not work. It just receive charge but does not work. If I disconnect it the GPS It work.
Are you using the garmin power cord or are you using an aftermarket cord? Some after market cords have usb plugs that although they plug right in to the power port on the unit, they tell the unit that you are updating the database. The unit displays only a picture of a computer connected to the unit and that's all it will do. Their is a way around this. Simply wait until the unit displays the about photo of the computer attached and then unplug the power cord from the unit. After the screen clears immediately replug in the power chord. This must be done quickly before anything appears on the screen. If you're too slow, simply repeat this step until you manage to replug the unit before anthing appears on the screen. Once plugged in as about the unit will operate normally on the external power source until you either turn it off or unplug it. Simple repeat above when ready to resume use.
Apr 01, 2010 | Garmin nuvi 200W GPS Receiver
Unit keeps losing power. Cord has power light and
I had the same problem. It was the pin inside the **** clamp that was broken. As I wiggled the plug in the unit the pin would dislodge. eventually the pin got lodged in the 12v power cord.
May 16, 2009 | Magellan RoadMate 700 GPS Receiver
POWER SWITCH DOES NOT ILLUMINATE GPS SCREEN WITH 12VOLT PWR.
bjw122266 Have you tried holding the power button down for about 10 seconds or so?
Dec 29, 2008 | Navigon 2100 Portable GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
Can't find info for power cable between units
I have a connector cable for the Dual 7 for sale for $29.99 including shipping to lower 48. any interest, email me at 1topwop@comcast.net. warm regards,
Jun 24, 2008 | Durabrand Portable DVD
Unit will not power on
Company said it was defective. Sent back for exchange.
May 30, 2008 | ViewSonic PJ501 Multimedia Projector
Keeps turning off
Your power cord is cutting in and out. You either have a bad power cord or there is something wrong with the connection to the cigarette lighter. When the unit say "Running on battery - will turn off in 30 seconds" this mean that it has lost external power. This is by design so that when you shut off the engine external power is cut to the unit and that it will shut down.
It a shame that for the C330 Garmin decided to remove the LED light from the power cord that shows the power cord is connected correctly to the cigarette lighter.
Jan 15, 2008 | Garmin StreetPilot C330 GPS Receiver
Delphi NA10000 Losses Power, Turns OFF
I had the same problem and was able to fix it by finding a replacement cigarette lighter power cord with the same voltage and polarity. Input to cord is 12Volts. Output to GPS is 5Volts, with a positive center post.
larryjm123
PS I need an instruction book and disks (or disk copies) if you know where I can get them. Delphi no longer has them.
May 14, 2007 | Delphi NA10000-11B1 GPS Receiver
Durabrand Portable DVD Logo
98 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
