Question about Calculated Industries Pocket Real Estate Master 3275 Calculator
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  • Calculated I... Master
  • 7,993 Answers
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Posted on Nov 19, 2009
80% from $70
Posted on Feb 14, 2010
I just need to know the four side dementions of a 1/2 acrelot the top and the bottom and both side demenstions .not the high or depth of the land just a flat peice of ground
An acre is 43,560 square feet, so a half acre is 21,780 square feet. If the lot is rectangular, you multiply the length of the long side (in feet) times the length of the short side (in feet). For instance if the lot is 200 feet x 110 feet, the area is 22,000 square feet, just a little over a half acre. If the lot is not rectangular, then you need to have a good knowledge of geometry to calculate the area.
Jun 04, 2017 | Cars & Trucks
How many feet are in.54 acres, planning on fencing my yard in wit PVC pipe. 7 foot walls in most of it
>.54 acres is just over a half acre.
My lot is 104 ft long and 104 wide and my deed says I purchased a half acre lot so you can go from there.
Hope this works for you.
Dec 23, 2016 | Office Equipment & Supplies
My lot is 290 feet by 290 feet by 381feet by311 feet.how many acres is that?
if we assume the two shortest lengths form a precise right angle the area is 86011 square feet
This will be divided by the number of sq feet in an acre which is 43560a
The result is 1.974540863177227
Jun 11, 2015 | Garden
What is the radius of a 3/4 acre circle (in feet)
Oh wow, lots of math going on here...
There are 4840 square yards in an acre and 9 square feet in a square yard (4840 x 9 = 43,560).
An acre is an old timers measurement used in agriculture...
it was 4 poles wide and 40 poles long. A pole is equivalent to sixteen and a half feet. So back then, an acre was a piece of farming land 660 feet long (220 yards or one eighth of a mile) and 66 feet wide (22 yards or one eightieth of a mile).
Acre is a measure of area, which would be square feet.
Feet are a measure of distance.
The best you could do is something like this:
An acre is 43, 560 square feet.
Draw/imagine a square or a rectangle that would cover that much area.
If it is a square, it would be (approximately) 208.7 feet on each side.
Its perimeter (the distance around it if you walk an imaginary fence around you acre-sized plot) would be 834.8 feet.
Trying to to figure out an acre of 'Circle' - hmmmmm???
Radius = 1/2 of Diameter
sorry, just can't wrap my head around this to come up with the correct equation.
maybe we can get lucky with some other brainiac taking what I did provide and come up with a solution for you?
Square - It would be 208.7 feet across if you walk across it, and the same if you walk the other way across it.
Apr 11, 2015 | PetSafe Wireless Fence System For Dogs &...
The dimensions of my lot are 83 X 192 X 150 X 151, what is the acreage
http://www.wikihow.com/Calculate-Acreage
Hmm. Width X Length = square footage.
Square footage divided by 43,560 = acreage.
You seem to have two lots. Is one 83 X 192 and the other 150 X 151? If so, sum those two products and then divide by 43,560 for the total acreage. If you want the acreage of each lot separately, divide 83 X 192 by 43560 for lot A. That is .3658 acre.
Then divide 150 X 151 by 43560 for Lot B. That is .5199 acre.
Total of both is roughly .885 of an acre, in other words about 9 tenths of an acre.
Mar 04, 2015 | Office Equipment & Supplies
What percent of an acre is 20,473.20 feet
One acre is about 53,560.17 square feet so 20,473.20 square feet is about 47% of an acre.
Feb 24, 2015 | Office Equipment & Supplies
How many feet in a half acre of land?
Since acre is a measure of area and feet is a measure of distance, you need to calculate the perimeter of a lot with an area of half an acre. Here are the formulas:
1. If the lot is a square (all 4 sides of equal length), multiply the length of one side by 4, to get the # of feet required to walk a half acre piece of land.
2. If the lot is rectangle: (heightx2)+(widthx2).
3. If the lot is a triangle, add up all three sides.
Dec 09, 2014 | Visual Land Audio Players & Recorders
1 acres =
One acre is about 4047 square meters or about 43,560 square feet.
Feb 20, 2014 | EnGenius FREESTYL1 Slim Design Long Range...
How big is 3,500 acres of land is it big as a football stadium?
An American football field is about 1.3 acres. Canadian football fields and soccer fields are bigger, and that number is just for the playing area. It doesn't include the room around the field or any seating for fans. However, if you have an additional 3498 acres to spare, you should be able to put in a lot of seating and a sizable parking lot.
Oct 28, 2013 | EnGenius FREESTYL1 Slim Design Long Range...
Calculated Industries Pocket Real Estate Master 3275 Calculator Logo
348 people viewed this question
Top Calculated Industries Office Equipment & Supplies Experts
k24674
Vernon Taylor
Joe Garcia
Joe Garcia
Are you a Calculated Industries Office Equipment and Supply Expert? Answer questions, earn points and help others
