Question about Texas Instruments TI-89 Calculator
What size & type are the screws that are in the backpanel of the TI-89, and the ones that are screwed the circuit board into the plastic front panel? Thanks. Mike
3 Suggested Answers
onomou
  • 24 Answers
SOURCE: TI-89 & Liquids :(
The screws on the back are Torx bits size T6. You can pick up that type of screwdriver at Sears (I got a set of 12 micro screwdrivers marketed toward jewelers and hobbyists from there - lifetime guarantee) or maybe a local hardware store. Unfortunately, I'm not sure that once you're inside you can do a lot to revive your calculator. Some liquids can really take their toll on electronic circuitry, and you will probably need a volt meter and some more sophisticated tools to test whether your components are still good. Your best bet is probably to contact TI and see if they will repair it for cheap. Otherwise, I've seen (and bought) some TI-89s for $50 or $60 off eBay and Craigslist.
Posted on Oct 03, 2009
  • 102366 Answers
SOURCE: ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Posted on Aug 01, 2010
Cannot seem to get the motherboard out after removing single tray support screw?
Most Dell desktop models use an industry standard mounting screw pattern. To remove a standard form factor motherboard, you must disconnect all cables (very carefully keep track of where all those little ones going to the front of the case go), remove any peripheral cards from their slots (although it is not necessary to remove the memory modules unless you plan to remove them anyway), then search for all and remove all of the screws attaching the motherboard to the base plate in the case. Generally, there are at least six screws: one or two in the peripheral card area near the back of the board, another one or two near the backpanel connectors, two in the memory module area in the middle of the board, another near the front panel connectors, and one by the main power connector. If the board still won't move after you've removed the visible screws, and the drive bracket overhangs part of the board, remove the drive bracket and look for a screw hiding in that area.
Jun 14, 2015 | Dell Precision 650 PC Desktop
Removing the covers on a viking 980
I assume you're talking about the main back and front cover. Unless you really are skilled, I'd leave this project to a professional.
I've worked on the Designer I, II type machine and I believe yours has similar construction. You need screwdriver bits with a 6 pointed "star" head. Screws in the cover itself are "H10" size. Screws in the base are "H15" size. The back cover has to be taken off first before you can get at screws for the front cover. Typically there are 5 screws on the back cover that have to be removed and 2 in the bottom of the base. Note that the front and back covers "snap" together and have to be unsnapped after the screws are removed. If you have to take off the front cover (requires removing more screws in the cover and base), be careful with the various wiring harnesses that attach to the main circuit board.
Jan 13, 2013 | Husqvarna Viking 1
Tachometer 1997 pathfinder erratic RPM
I just solved this problem on my 1997 with 183K miles . First I checked all of the following:1) sensor on distributor; 2) wires from distributor to back of instrument cluster; 3) connections of wires to instrument cluster; 4) 4 screens going through the soft circuit board to tachometer; 5) the SOLUTION- I removed the tachometer from the instrument cluster and looked at the hard circuit board of the tachometer. On one side there is a plastic square housing about 1/4 x 3/8" soldered to the circuit board that has a plastic screw facing out. it was lose, so I tighten it and now my tachometer is OK. A simple test to check for this type of an error is hit your dash when the tachometer is erratic. if you see a fluctuation based on the tap on the dash you either have a lose connection of some type like this one. Fix is easy, once you have the instrument cluster out you only have to remove the four screws on the back of the cluster holding the tachometer in place. Remove the tachometer carefully and tighten the plastic screw being careful not to over tighten.
Mike T
Apr 14, 2012 | 1997 Nissan Pathfinder
How to remove and change the battery in a Tom Tom GO 540 Live.
Answer: AnswerI have TomTom 910 in USA, (and I have one in the UK). Access to the battery is behind the front screen but the plug is under the circuit boards.
1) Remove 4 screws under ends of rubber strips on back. (All screws are Torx number 6)
2) Remove back cover. Front frame around screen comes off easier now.
3) Remove 2 screws in round top circuit board. Remove 4 screws from lower circuit board. These two boards may have a glue connection. Do not worry if it separates
4) Lay back circuit boards to unplug battery. Note flat ribbon cables are fragile. The 3 wire plug is the battery. Unplug wires to battery from receptacle on circuit board.
5) Remove front screen by pressing a screwdriver against the small metal tags that follow the edge of the screen. The tabs need to be pushed in slightly to allow you to lift the screen out. It may need some leverage, but be careful not to put the screwdriver to far behind the screen as there are a couple of thin cables for the connections.
6) To remove the hard drive you may need to unscrew the vertical black tags about 2 cm long. These simply come away and are grasping the business card size silver box IE the hard drive. The rubber end caps are pressed in, pry out with small screw driver.
7) Remove battery and replace. Note the two sided sticky tape around battery. When putting more tape on, be careful you do not put to much around the right hand end as it will connect with the thin cable when you put it all back together.
9) Reverse assembly. Mine works fine now, good luck. (and so does mine! BLP)
Footnotes: I did not have a Torx #6 screwdriver nor could I buy one locally. I found a #7 mini star bit works just fine. Source: Harbor Freight item # 93316, 6 piece Mini Star Bit Set - $3 PMVN - 9/19/2009
I am not advertising but Batteryship.com included with the battery #5 & #6 torx screwdrivers, a very small philips (star), a straight screwdriver and a plastic pry tool. Whatever I paid more than another place it was worth it.
When disassembling do not remove the battery clip. Just pop out the battery from the front (experienced having to reassemble that whole thing). Also having a set of tweezers to put the electrical connections back together helped a bunch.Not sure if this will help but they may be close designs
May 24, 2011 | GPS
Screws from sony cybershot dsc-p100 are missing
This can present a problem.
You must know what sizes the screws are. Some cameras have more than four kinds of screws on the case. If the screw is too long, then it can touch some component or the circuit board and could cause a short and ruin the camera.
Try to find someone with one like you have and get the kinds and sizes of the screws. I have Nikons, Canons, Panasonic, Sony and others and hardly any of the screws are the same in the different brands, or differ in kind such as wood type thread for plastic, fine thread, course thread and others. Plus, the sizes of the screw and the length will vary. The colors can vary as well as the type of head of the screw.
Another possibility is to get a broken camera from a site such as Ebay. Buy the camera, remove and use the screws you need, then resell the camera as a repair, as is repair camera.
Oct 07, 2009 | Sony Cyber-Shot DSC-P100 Digital Camera
Replace Control panel cover on dishlex dishwasher 500E
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
May 09, 2009 | Dishwashers
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Mar 21, 2009 | Kenmore KTES8 Toaster Oven with Convection...
Internal fuse
The Solution:
1. Firstly unplug the decks!!!
2. Remove the slipmatts and platter
3. Unscrew the circular plastic cover (Note: 5 screws holding it down)
4. Upon removing this circular plastic cover you will see a clear piece of plastic covering a circuit board, open it up. Now you will see a two fuses one clear and one stripey. 5. Remove the fuses (Gently poke it out with a pen/screwdriver or whatever) and examine it and see if either or both have infact blown.
6. Bring the suspect fuse/s to any electric/hardware/music type store (or search the net) and try to get a replacment but make sure its the same as the fuse you removed!!!. A T250 mA fuse(clear) an a T1A Fuse (stripey) are stated in the Technics user manual.
7. Now get the new fuse and gently snap it back in to the silver holders.
8. Replace the clear plastic circuit board cover.
9. Screw back the the circular plastic cover (Note: 5 screws holding it down)
10. Replace the Platter and slipmats
Sep 04, 2008 | Technics SL-1210 Turntable
Getting to the circuit board
First, remove the plastic vent / louver going across the top of the unit. Once that's off, you should see one phillips screw at the top of the control panel frame. Remove that screw, then lift up and out on the control panel assembly. You're there!
Jul 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
TI-89 & Liquids :(
Dec 13, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
141 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
