Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
My 40 inch Samsung LCD TV was working fine then began flashing from snow to a black screen to a BARELY visible, distorted picture. Swapped cable box and still have an issue. The component video is working for my DVD player. Could the HDMI input be shot? Maybe the HDMI Cable itself?
Try a new HDMI - I had a cheapo from walmart and I tried a Monster HDMI and it worked beautifully
Posted on Nov 28, 2009
My 58 inch Samsung Smart TV picture distorted, flashed vertical lines, and went black except for curved lines on the very right edge after being moved to my new house. It was working perfectly before.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Dec 23, 2016 | Samsung Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Sometimes tv sreen comes on then goes black, in the right lighting you can see the barely see the picture, other times the screen wont come on. either cse the sound works fine
Sounds like the backlight or backlight inverter is out on your TV.
You will likely want a seasoned professional to repair this for you assuming the TV is out of warranty.
Sep 05, 2011 | Samsung LN-S4051D 40 in. LCD Television
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Samsung 650 lcd 40" tv picture blacks out for a few seconds.
Dude, better check your cable and also your TV's power management settings. This might also happen due a issue with the HDMI output of the satellite box.
Jan 07, 2010 | Samsung LE40B650T2 40 in. Full HD Crystal...
Samsung LCD TV ''Weak or No Signal''
try swicth cable box for testing....if sam problem..need replaced tv main board
Jan 01, 2010 | Samsung LN32A330 32 in. LCD TV
I have a 42 inch samsung and the sound is fine
Is it still covered under warranty?
If not - you have a bad processing board and will need to be replaced.
Blessings,
A/V Guy
Nov 19, 2009 | Samsung LN-T4665F 46 in. LCD Television
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Mar 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
329 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
